4.2L V6 Swap to 5.3L V8 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 5.3L V8 Engine and Drivetrain > Engine Tunes/Mods
Engine Tunes/Mods Performance Engine Tuning/Engine Modifications
Old 08-30-2013, 04:48 PM
Venomhatch's Avatar
Venomhatch Venomhatch is offline
2002 Chevy Trailblazer LS/SS Clone
EDIT: I meant to say I have a 4.2L I6 Engine.
I am looking at a possible good deal. There is a shop near me that my father-in-law knows the owner. Well in the shop they have a v8 motor from a newer model suburban probably around 2004+ I believe it is a 5.3L v8. I am wondering to the best of your knowledge would that motor be able to go into and replace my 4.2L Inline 6? Just curious, I know you may need to know more info. But if there is anything I need to look for, aka engine codes written somewhere on the motor, etc let me know what I need to look for.
Thanks
D~
Old 08-30-2013, 05:43 PM
realz69 realz69 is offline
Silverstone Metallic 5.3L V8 2WD
4.2l v6?
Its a bolt in swap use the same mounts and wire harness they are identical on the v6 and 5.3 v8 both engines. The only one that is not a bolt in is when you have a 4.2 I6 then its not worth it for the swap because everything is different.
Old 08-30-2013, 05:54 PM
Venomhatch's Avatar
Sorry typo on my part. It is 4.2L I6
Old 03-01-2014, 02:05 AM
2006Trail_LT's Avatar
2006Trail_LT 2006Trail_LT is offline
2006 Chevy TrailBlazer LT
Black Granite Metallic 4.2L I6 2WD
Swap in progress
I'm starting to swap the 4.2 to the 5.3 this weekend any and all info will be taken into considertion, already have a 2004 5.3 from a silverado done the transmission research it will bolt right up my only issue as i sit is the wiring harness but i am looking into splicing a 5.3 wiring harness with PCM with a 4.2
Old 04-10-2014, 09:07 PM
RyanA RyanA is offline
2002 Olds Bravada
Black 4.2L I6 AWD
Your other issue you are soon to realize is the I6 has the trans crossmember welded in at a different spot. Yes, you can definitely cut it out and weld it back in or weld another in.
Old 09-06-2016, 01:11 PM
shoesnower shoesnower is offline
swap
How did the swap go?
Old 06-18-2017, 01:49 PM
seanb81 seanb81 is offline
2007 GMC TrailBlazer LS
Sand Beige Metallic 4.2L I6 4X4
going necro on this with a bump. i found some 5.3's being parted out, have plasma cutter, welder, and energy drinks. has nobody pioneered this? i've searched for hours and not found a single soul claiming to have done it, and it'd seem to be a trivial swap (relative to other swaps).
