still overheating - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 4.2L I-6 Engine and Drivetrain > Engine Tunes/Mods
Engine Tunes/Mods Performance Engine Tuning/Engine Modifications
Old 07-01-2018, 12:34 PM
clockmanbill clockmanbill is offline
still overheating
When I got my 2005 tb, after a few trips it started overheating. It was fine till
I got on the highway and ran around 70. Than the gauge would go up about 3-4 marks over the center. I replaced the water pump, thermostat, coolant temp sensor, fan clutch and radiator. Now it goes up to 2-3 marks. When I slow down or stop it goes back down. I'm going to be pulling a camper this year , should I worry about it? Any help?
Old 07-01-2018, 12:43 PM
miketexas miketexas is offline
2003 Chevy TrailBlazer LS
Black 4.2L I6 2WD
Put a scan tool on it and see what the actual temp says.
Old 07-01-2018, 02:39 PM
over heating
Ill try that. where should I take readings?
Old 07-01-2018, 06:18 PM
Black 4.2L I6 2WD
Where you hook the tool up at the OBD port under the dash, driver side.
It looks similar to this:
Old 07-03-2018, 01:33 AM
Cctb Cctb is offline
2006 Chevy TrailBlazer LS
Summit White 4.2L I6 4X4
I had some issues with overheating. If it's leaking coolant, you may have a bad hose or hose clamp somewhere.
Sent from my SM-G950U using Tapatalk
Old 07-03-2018, 12:59 PM
leak
not leaking coolant, put on a new lower hose when I put in new rad. The gauge does go back down , It's been over 100 here for the last 3 weeks. Could it just be to hot to keep the temp down?
Old 07-04-2018, 07:45 PM
thelcpl87 thelcpl87 is offline
2008 GMC Envoy SLT
[QUOTE=clockmanbill;1590665]When I got my 2005 tb, after a few trips it started overheating. It was fine till
I got on the highway and ran around 70. Than the gauge would go up about 3-4 marks over the center. I replaced the water pump, thermostat, coolant temp sensor, fan clutch and radiator. Now it goes up to 2-3 marks. When I slow down or stop it goes back down. I'm going to be pulling a camper this year , should I worry about it? Any help?[/QUOTi had the same problem with my 08 envoy just installed a transmission oil cooler that helped drop the temp a couple of degrees
Old 07-04-2018, 11:43 PM
regionvoices regionvoices is offline
Envoy GMC Envoy SLE
[QUOTE=thelcpl87;1590785]
The gauge has a stepper type motor that are notorious for being inaccurate. Perhaps you should try a laser hand held temperature gauge and see if the temperatures match or are close to the same. My guess is the stepper motor on the gauge is faulty
Old 07-05-2018, 12:31 PM
Atoy Atoy is offline
2004 Chevy TrailBlazer LS
Indigo Blue Metallic 4.2L I6 2WD
Electronic cooling fan clutch
These vehicles have the terrible electronic fan clutch that apparently was so troublesome that GM abandoned it and went back to a mechanical fan in 2008.
My 2004 TB will not pull a small camper in weather above 80 degrees without overheating and I tried almost everything, including a overhaul of the entire cooling system and exhaust. The only fix that finally worked was a Fan override that requires bypassing the computer to force the fan to run full speed.
Someone said they put a 2008 mechanical clutch on the 04 and it worked. I have not tried that one.
Old 10-25-2018, 04:02 AM
denisbill denisbill is offline
