Where is the coolant temp. sensor on 2009 TB - Page 2 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 09-13-2019, 12:45 PM
rums2sun rums2sun is offline
2008 SAAB 9-7x
Onyx Black 4.2L I6 AWD
There is another thread showing the Thermostat fixed this issue.
Search Forums for Temp Gauge not reading and look for the thread titled:
Temp Gauge doesnt work, A/C goes out too
Old 09-15-2019, 09:47 AM
thursamhank thursamhank is offline
2008 Chevy TrailBlazer LS
Moondust Metallic 4.2L I6 2WD
air and temp problem
2008 same problem, replaced the temp sensor twice, took it to chevy and they found the thermostat stuck open, and the low pressure ac switch leaking, all fixed now, ya.....
Old 09-15-2019, 04:18 PM
RPatton76 RPatton76 is offline
Let us know if the issue ever returns. For mine, it comes back basically daily, so I figure it's the ECM. Maybe one day I'll change it, unless there is some other thing that provides CAN BUS info from things like coolant temp. senders.
Rob in AZ
Old 09-19-2019, 07:45 AM
DDS-029's Avatar
DDS-029 DDS-029 is offline
2003 GMC Envoy SLE
2008? Thermostat is cheap insurance for an engine that old, in any case. Especially if the cooling system could some other maintenance.
Old 09-19-2019, 08:11 AM
Jim_Owens Jim_Owens is offline
After reading all the comments, I just went ahead and changed the thermostat instead. Since the problem I was having was fairly intermittent, we'll see if just doing that fixed it. Thanks for all the responses. They were very helpful.
Sent from my SM-N950U using Tapatalk
