Shocks - Page 2 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Suspension Suspension
Old 04-07-2007, 07:44 PM
LineNoise's Avatar
LineNoise LineNoise is offline
2003 Chevy TrailBlazer LS
Originally Posted by the roadie View Post
No realignment needed. Not Harbor Fright. $75 set from Autozone. They also loan them out for free or cheap. I just believe in buying good tools, and I've used this set five times, three times for me and once each for two local wheeling buddies getting BDS lift kits.
Fair enough! I will get one from there then! Well I just odered the shocks, now I have to get a bigger jack. lol.
Old 04-09-2007, 11:34 PM
Sparty's Avatar
Sparty Sparty is offline
2002 Chevy TrailBlazer LS
Z71 . Onyx Black 4.2L I6 4X4
Originally Posted by LineNoise View Post
Now I just have to find a spring compressor for the fronts. Roadie, your's looks like the one from harbor freight, would you reccommend it? (for most likely for a one time use)
Do not get those, borrowed a set of Harbor Freight ones and uses an impact to make it go faster, the threads of the bolt welded themselfs to the nuts while doing the first coil spring. Had to go to Autozone and borrow theirs to get the cheap ones off since they wouldn't loosen back up.
  #13
Old 04-10-2007, 01:48 AM
Gearhead2012 Gearhead2012 is offline
I've got an impact wrench...but, i've heard some mixed things with using them. Obviously it makes it go quicker...but, how about the safety issue? As well as cheap parts giving in, as mentioned about Harbor Freight. I mean...is it ok, if you just do a little on each side at a time? or, what's the rules regaurding that?
  #14
Old 04-10-2007, 11:59 AM
Buddyrich Buddyrich is offline
2003 Chevy TrailBlazer LT
Pewter Metallic 4.2L I6 4X4
Bilsteins HD vs. Monroe
Has anyone had any experience with Monroe shocks on the Trailblazer?
What would be the difference between the Bilsteins HD and say the Monroe Sensa-trac?
  #15
Old 04-10-2007, 02:37 PM
Spong's Avatar
Spong Spong is offline
TrailVoy Guru
2006 Chevy TrailBlazer LT
Zaino Shined Red Jewel 5.3L V8 4X4
Monroe makes good shocks but compared to the Bilsteins, there's no comparison!!
When I had my 00 Jimmy, I replaced the stock Bilsteins with Monroe Reflex shocks and they sucked. I pulled them out and put in HD Bilsteins and I LOVED them! Spend the extra $$$, you won't regret it!
BTW, I replaced the stock shocks on my 06 TB with HD Bilsteins at about 9200 miles and I love them!!
More info: https://forums.trailvoy.com/showthrea...ighlight=spong
  #16
Old 04-20-2007, 02:33 PM
Well I have the Hotchkis rear sway bar, the rear Bilstein HD shocks and the front and rear Spicer stabilizer end links installed. I still have the front OEM shocks.
WOW, what a difference. The ride is really stiff. You can feel that the back end of the truck is firmly planted to the ground now. When stopping, you don't have the nose dipping now, nor do you have it coming up on exceleration from a stop. Turns are tight and gone is the body roll. Steering is tight and responsive and you feel more of the road in the steering wheel as well as in your seat. The ride is rougher, and hopefully it may break in a little or I can get used to it.
It is definately a sportier / tighter ride with a more responsive feel.
  #17
Old 04-20-2007, 03:54 PM
Spong's Avatar
TrailVoy Guru
I've got almost 2k miles on my HD Bilsteins and Hotchkiss rear sway bar. They do "settle in" some and smooth out. Mine now feels just as smooth as with the stock shocks but the handing is still 1000% better.
Similar Threads
Cant find SS shocks in stock Where can I find them? colvinji Suspension 13 06-28-2008 12:25 AM
rear shocks recommendations.. PANGGOY Suspension 11 11-13-2007 03:25 PM
Drop & shocks Frostee Suspension 0 10-22-2007 09:55 AM
2" rear kit, Do I need Shocks ?? 2004AscenderEXT Suspension 12 05-13-2006 07:56 PM
Need help on new shocks dirthopn1 Suspension 4 04-24-2006 07:22 PM
