Problems with my wheels when added beltech - Page 2 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Suspension Suspension
Old 05-08-2007, 09:22 PM
LMMJ's Avatar
LMMJ LMMJ is offline
2002 Chevy TrailBlazer LS
Indi-GO Blue Metallic 4.2L I6 4X4
I have been on this for quite a while. There is simply NOT enough adjustment in the control arms and I do alignments for a living. I'm at -1.8 & -1.6 degrees camber. I have even gone as far as removing the lower control arms and removed about 1/4" of material from the adjustment slots. It did NOTHING. We either need DJM control arms or offset upper ball joints. I'm gonna try and get some stock upper control arms and straightening them in a press as they are slightly curved.
Luis
Old 05-08-2007, 11:08 PM
SIK ENVY's Avatar
SIK ENVY SIK ENVY is offline
Senior Member
2004 GMC Envoy SLE
Onyx Black 4.2L I6 4X4
looks like your on the case too! keep me informed on your progress! good lookin out!
2004 ENVOY SLE 4x4 "SIK ENVY"
  #13
Old 05-08-2007, 11:44 PM
BUC NASTY's Avatar
BUC NASTY BUC NASTY is offline
2002 Chevy BigBlazer SS Clone
Indigo Blue Metallic 4.2L I6 2WD
Originally Posted by synthes02 View Post
When did you drop your TB ?
i had it done both in the chevy dealer and sears with the same explaination as what every just posted. I didnt have any problems when i had GF probally i should install them back in
SS Conversion, SSBC Brake Kit, Avic D3, 22in Rims, Efans, 6000k Kits, SS Wiper Cowl, 35% Tint, Race Mesh Grills
  #14
Old 05-09-2007, 12:01 AM
ghoster ghoster is offline
2011 Chevy Tahoe
Mocha Steel Metallic 5.3L V8 4X4
A few weeks ago.
So whats the difference here?? Mine aligned with no problem. The guy warned me before hand that it may not, but he said it came out perfect. He used some big fancy Hunter machine with all the fancy lasers and stuff to do it. I wonder what the difference is
  #15
Old 05-09-2007, 12:45 AM
SIK ENVY's Avatar
Senior Member
2004 GMC Envoy SLE
the difference is that the guys with the camber (like myself) are rollin 4x4. apparently it gets in the way of the suspension and the thingamabobers!
  #16
Old 05-09-2007, 12:50 AM
2011 Chevy Tahoe
ahhhhh I see that now. So its not an issue on the 2wd trucks. Now I get it.
  #17
Old 05-09-2007, 02:08 AM
ScarabEpic22 ScarabEpic22 is offline
Northwest Chapter
not here not here not here
not here Other AWD
A few weeks ago.
The Les Schwab near my house aligned my TB with nary a problem, and I spoke to the guy afterward who said it was barely out of alignment. The machine they have is one where you drive up and it lifts the car up in the air about 2-3ft then there are a bunch of sensors they install on the tires and whatnot.
  #18
Old 05-09-2007, 02:10 AM
2011 Chevy Tahoe
well, thats one 4wd that aligned ok. That sounds like the machine they used on mine, I just happened to notice that it was made by Hunter. Wonder why yours aligned so easily Really does sound like its hit or miss with this issue.
  #19
Old 05-09-2007, 09:36 AM
LMMJ's Avatar
I really doubt it's the 4X4 causing the misalignement. All the parts are the same except for the CV axle is there on the 4X4. I also used a Hunter drive on rack.
ghoster and scarab you guys rollin the factory wheels right? That's another difference between the screwed up camber crew and the not so screwed up camber.
Also, did you guys get printous of the before and after readings? Recently at work I've been having people comming in and saying some shop aligned their car but gave them no printout and the tires are all jacked up. Checked the alignment and it was waaaay out. It's impossible for it to go out the way these cars did. So again, did you guys get printous of the before and after readings and can you post the after for us Please?
Luis
  #20
Old 05-09-2007, 05:07 PM
rmac694203's Avatar
rmac694203 rmac694203 is offline
Senior Member
2006 Buick Rainier
Titanium Metallic 5.3L V8 AWD
So would the Ground Force kit be easier to align as it doesn't drop the front as much?
Similar Threads
Does anyone want to go 1/2 on ss wheels? NORCAL SS Rims 6 05-17-2006 06:03 PM
22" wheels Emmerrrrr Rims 3 04-25-2006 06:46 PM
Full time 4WD citori3 4x4 Drivetrain 18 02-16-2006 09:34 PM
lowering coils any problems with the wheels butterflying? nando408 Suspension 8 11-08-2005 10:08 AM
Problems when Towing [long...] Matt_Lewis 02-09 Vortec 4.2L I-6 Engine and Drivetrain 19 08-30-2005 06:06 PM
