Wonder what a GearVendors OD would do to MPG ? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > The Lounge > TrailBlazer SS Chat
TrailBlazer SS Chat The TrailBlazer SS Owners and Enthusiast lounge. (no tech questions)
Old 12-19-2005, 02:43 PM
SSportWagon's Avatar
SSportWagon SSportWagon is offline
2005 GMC Envoy SLT XUV
Indigo Blue Metallic 5.3L V8 4X4
Anyone know if theres room under there (2WD) for an OD unit, like Gear Vendors ??
That would knock the effect rear gear ratio down to 3.20's
Alan W
Old 12-20-2005, 03:46 AM
turboawd turboawd is offline
how much would it cost to install? and then figure out how much gas you'll save. it would probably take a loooong time to get back your money from the od unit, and then some.
Old 12-20-2005, 05:41 AM
TBSS's Avatar
TBSS TBSS is offline
Senior Member
2006 Chevy TrailBlazer SS
Liquid Silver Metallic 6.0L LS2 V8 2WD
I've thought about this. The GV unit requires very little space whatsoever, so that would not be an issue. However, at $2,595 for the unit (plus install), that's a lot of cost to make up.
Check out here what happens to your RPM when you tack on a GV OD unit to the TBSS (effectively adding an additional .55 overdrive onto the stock .70 overdrive).
As you can see, if your average speed on the freeway is 80 mph, instead of ~2700 RPM bone stock, you will be cruising at ~2100 RPM with the GVOD. What that 600 RPM translates into as far as MPG increase is anyone's guess. I would say 2-3 MPG max.
Old 12-20-2005, 08:25 AM
TrailblazerSS's Avatar
TrailblazerSS TrailblazerSS is offline
Senior Member
Silver 6.0L LS2 V8 AWD
If you can get it installed with the new drive shaft for $600 and Gas is $3.00/gal and you save 4 mpg, you still have to drive 95,000 miles to break even.
06 TB SS...98 Camaro SS... 07 Cobalt SS
Old 12-20-2005, 05:34 PM
Sid3ways Sid3ways is offline
Old 01-17-2006, 10:19 PM
SlvrTBSS SlvrTBSS is offline
I just came across this post and realized what you guys were missing. In addition to the overdrive, the gear vendors also splits your gears. Basically giving you an overdrive in every gear. This would make it an 8 speed transmisson and the engine would be going through its peak powerband more times during acceleration and it would make it a whole lot faster.
Old 01-17-2006, 10:49 PM
OurZoo OurZoo is offline
Hmmmmmmmmm, faster is good!
Old 01-17-2006, 11:10 PM
TBSS's Avatar
Senior Member
You're forgetting to take into account the time it takes to shift (a shift is not free). And also that the GV is a manual shift. You have to turn it on and off between gears....as a result, timing is critical, as you can imagine.
There are a few issues associated with integrating a GV overdrive into your modern 4-speed vehicle that are not no-brainers.
2006 TBSS Silverstone Metallic 2WD LT
Old 01-17-2006, 11:41 PM
Yes you are correct about the timing issue. I know for a fact that you could rig the electrial switch to shift the OD on and off by itself after each shift. This is something I was looking at doing for my 67 Camaro w. a TH400. Obviously a lot simpler with the TH400, but it is possible with the 4L70...
Old 01-18-2006, 11:37 AM
....and you're not going to use all 8 possible gear choices as several are going to overlap
Alan W
Similar Threads
Automotive Thrill Stories from Driver's Ed 02-Bravada-88 Everything Off-Topic 69 11-05-2013 07:41 PM
What goes on in other car forums... Sport_truck Everything Off-Topic 18 08-28-2010 10:56 PM
Prius Outdoes Hummer in Environmental Damage Zibby Everything Off-Topic 13 02-02-2009 05:19 PM
synthetic oil wmolzon 02-09 Vortec 4.2L I-6 Engine and Drivetrain 51 06-28-2007 11:10 AM
First good race...it was a draw Blue Beast Racetrack Results 6 03-30-2007 12:21 AM
