Cam Sprocket Bolt (single bolt instead of three) - Page 2 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2006 - 2009 TrailBlazer SS Tech > 06-09 SS Engine and Drivetrain > Engine Tunes/Mods
Engine Tunes/Mods Engine tuning and/or modifications
Old 11-26-2007, 07:55 AM
DRCE DRCE is offline
Originally Posted by ADM PERFORMANCE View Post
1 OTHER TIP - Get a couple extra tork bits for the cam plate.You think the cam bolt is hard to remove,wait till you get to these four torx.
Sorry I missed that one earlier.
Andy
Oddly enough I breezed through that part. I've got some MAC torx bits that are pretty stout.
Old 11-26-2007, 09:16 AM
ADM PERFORMANCE ADM PERFORMANCE is offline
-Mac tools and Ingersollrand baby
  #13
Old 12-23-2007, 07:16 PM
ZO6_Bryan ZO6_Bryan is offline
2006 Chevy TrailBlazer SS (3SS)
Black 6.0L LS2 V8 AWD
Timing chain dampner/tensioner,2007 has this on the passenger side of the block right behind the front cover.The chain rides on it.
If you done alot of ls1's you would have never seen the dampner block(only on ls2).On 2007 single bolt cams they use a tensioner and no dampner block.
Just use the 2006 corvette stuff and youll be fine.
My prayers are with you if it is all wheel drive,factor in 3 more hours to do it right.
How does the AWD affect a cam swap? Want to know because I have a 2006 AWD.
  #14
Old 12-24-2007, 07:42 AM
It does not affect the cam swap unless you want to shim the oil pump for more pressure.
You cannot get the oil pump on and off easily without dropping the pan.You cannot get the pan down easily when you have a diff mounted to it.
We in Texas don't have ths problem since there are virtually no AWD here.
BTW-In 2006 you had 3 bolts in the cam so your ok.It is the 2007 awd that suck,because you have to pull the oil pump to do the job right!
Similar Threads
Not happy w/LPE GT2-3 cam! TXSS Engine Tunes/Mods 44 07-25-2007 07:59 PM
New Gt11 Cam A Success! quiksilver Engine Tunes/Mods 15 07-24-2007 10:17 AM
Cam installation, various tips for the DIY'ers.... 02redhawk Transmission Mods 5 07-09-2007 10:09 PM
