The whats, whys, and hows to removing your exhaust resonator (WITH PICS) - Page 3 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 4.2L I-6 Engine and Drivetrain > Exhaust Mods
Exhaust Mods Performance Exhaust Modifications
Old 02-12-2009, 09:07 PM
goulds48's Avatar
goulds48 goulds48 is offline
2005 Chevy TrailBlazer LS
Black 4.2L I6 4X4
I cut the resonator, got a corsa tip for a great price off of ebay, welded it on and painted the pipe black to the tip with VHT primer and flat black header paint from Auto Zone. Looks and sounds great. Corsa part number 14035, mine looks great. http://corsaperf.com/CorsaVehicleLookup.aspx Also I had to buy an 18" peice of pipe to weld it, sorry I forgot to add that
Old 02-12-2009, 09:10 PM
Michblaze02's Avatar
Michblaze02 Michblaze02 is offline
2002 Chevy TrailBlazer LS
Any pictures of yours
Brad-Midwest Chapter MI Rep
  #23
Old 02-12-2009, 10:03 PM
TRAIL-BLAZING's Avatar
TRAIL-BLAZING TRAIL-BLAZING is offline
Senior Member
2008 Chevy TrailBlazer LT
silverstone 4.2L I6 2WD
I just removed my resonator over the weekend. The tip is made by SLP 2-1/2" inlet x 4" out.
  #24
Old 02-13-2009, 07:17 AM
bobbyblaze's Avatar
bobbyblaze bobbyblaze is offline
Senior Member
2004 Non-GMT360 Other
Desert Tan Other 4X4
Pix of my rearnded TB. 'Death to the Resonator'
[QUOTE=bobbyblaze;677172]I was rear ended just before christmas. No real damage to my TB with the exception of the exhaust. The front end of the ford fusion that hit me was DESTROYED. My problem is the factory replacement tailpipe hangs 1 1/2 to 2 inches lower than stock. I measured 8 other TBs in parking lots to be sure. The body shop says that it is how the replacement came from the factory. Aside from the fact that the resonator is already ugly back there, it now hangs way too low for my taste and I plan on doing some 4 wheelin in the spring. I am going to cut out a perfectly good 2 month old resonator to weld in a straight pipe. YES !!! Just gotta find the right tip. I've seen some nice ones in this thread. Gave me some ideas.
Click image for larger version
Name:	Smaller img_ 149.jpg‎
ID:	2561   Click image for larger version
Name:	smaller other tb rear.jpg‎
ID:	2562   Click image for larger version
Name:	smaller tb rear 2.jpg‎
  #25
Old 02-13-2009, 07:26 AM
goulds48's Avatar
Black 4.2L I6 4X4
I will take a couple this weekend
  #26
Old 02-13-2009, 07:39 AM
juggalo's Avatar
juggalo juggalo is offline
2006 Chevy TrailBlazer LS
Superior Blue Metallic 4.2L I6 2WD
if i decided to cut it off would i HAVE to get extra pipe to keep the fumes from under the car and do you have to weld on the tip or can you just use one of the pipe clamps
  #27
Old 02-13-2009, 09:01 AM
bobbyblaze's Avatar
Senior Member
Dosen't matter wether you weld or clamp on a tip. Extending the pipe further is in my opinion nescesary to keep the exhaust gas from entering your tb when you are idiling. It looks like you'd have to cut the pipe just after the rear exhaust hanger before the res can. I do my own welding and can get a clean weld there, I would cut it at the rear of the weld bead where the pipe and res can meet (see the red arrow in the pic). Not alot of room between there. Gonna remove the tire for more room. You can go straight out back or out the side with your new pipe.
Name:	TB RES 2 arrow.JPG‎
  #28
Old 02-13-2009, 10:12 AM
juggalo's Avatar
thanks alot im defently gonna look into doing this and the pics always make it easier
  #29
Old 02-13-2009, 11:11 AM
bobbyblaze's Avatar
Senior Member
If anyone is interested, I will take pix for a how-to when I do my res can delete. Trying to find a nice stainless tip first.
  #30
Old 02-13-2009, 02:35 PM
2003 GMC Envoy SLT
[QUOTE=bobbyblaze;677443]
#1) If that's the way it came from the factory, it should have been sent back. #2 You should post the name of the body shop so people know where NOT to go. IMO.
