How to: SMAXX "MAXXlinks" sway bar end link installation. - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Suspension Suspension
Old 09-19-2009, 08:09 PM
MrSmithsTB MrSmithsTB is offline
Super Moderator
Mid-Atlantic Chapter
2002 Chevy TrailBlazer LS
This is not an official instruction guide, just how I went about doing it.
Tools needed:
Socket wrench set
18mm deep socket
3/4'' deep socket
9/16'' deep socket
19mm open ended wrench
T40 torx bit(for better grip)
Channel lock pliers
rotary tool
penetrating lubricant(PB Blaster)
Goggles(or cool sunglasses) and gloves
Jack stands
At least 1/2 ton floor jack
*I have included a few pictures to illustrate the before and after. The work involved is pretty straight forward*
*spray all bolts with penetrating lubricant for at least a few days prior to the install*
1. Properly raise vehicle with floor jack and support with a jack stand before removing wheel. Once set on jack, remove wheel and place to the side. I put the parking brake on for good measure. I did this one wheel at a time to ensure as much stability as possible.
2. Using the deep 18mm socket, break the OEM sway bar end link nuts loose, both upper and lower. You may need to temporarily remove the bump stops to gain access to the upper mount in the rear.
3. Attach the T40 bit to the socket wrench and insert in the opening at the end of the bolt. Hold this stationary and use the open ended wrench to turn the nut.
-the lower nuts removed with no problem, but the uppers had to be "coaxed". I used my rotary tool to cut relief grooves in the nuts, allowing them to move more freely. On one of them, I was required to use channel lock pliers to hold the bolt in place from the back end while turning the nut with the 18mm deep socket. I was in such a rush to get it finished that I forgot to take pictures ops:
Now the old end link can be safely removed. Here is a side by side comparison.
Installing the new end link is a simplified reverse of the removal.
4. Put the new end link in place and finger tighten the nuts to keep it stable.
5. Using the crescent wrench, hold the bottom in place. The rear links will have the nut facing down, the fronts will have the bolt head facing down. The deep 9/16'' socket should be used on the top to take the slack out. Use your better judgment to make them snug without crushing the bushings. Then, use the 3/4'' deep socket to tighten the end link nuts to the specified 65lb/ft of torque.
The finished product on the passenger rear.
6. Reinstall the wheel and lower the vehicle back to the ground.
Repeat this on all four links and you will be good to go! No more squeaks or clanks caused by the end links
Old 09-19-2009, 09:43 PM
DZP's Avatar
DZP DZP is offline
2003 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 2WD
Very interesting. It appears that they have eliminated the ball socket on their unit so the only thing to wear over time are the bushings. Very nice!
Old 09-19-2009, 09:51 PM
LMMJ's Avatar
LMMJ LMMJ is offline
Indi-GO Blue Metallic 4.2L I6 4X4
now that I think about it, you never have to remove the eyelets either. Just the big bolt and it'll come apart.
Luis
Old 09-20-2009, 02:44 AM
Dj Ethics's Avatar
Dj Ethics Dj Ethics is offline
2003 GMC Envoy SLE
Black 4.2L I6 2WD
Will these work with GF 2" Drop Springs and Belltech Nitro Drop 2 Shocks?
Old 09-20-2009, 10:11 AM
Super Moderator
I've wondered that, as the site claims they can be used from stock to 2" of lift. They are the same size as the OEM links, which gave me no problems when I had the GF lowering kit. Perhaps the front links, which are smaller, can be used front and rear....
Old 09-20-2009, 10:34 AM
MAY03LT's Avatar
MAY03LT MAY03LT is offline
TrailVoy Guru
2003 Chevrolet TrailBlazer LT
Scratchy Black 4.2L I6 4X4
I had to do this on every bolt on my OEM fronts, even after pb saturation. It was SO not cash.
Nice how-to. Are stunner shades and locs approved cool sunglasses?
Old 09-20-2009, 03:57 PM
Super Moderator
Straight up. I rocked it Tone Loc style
Old 09-21-2009, 11:03 AM
blktblazer04's Avatar
blktblazer04 blktblazer04 is offline
Senior Member
2004 Chevy TrailBlazer LS
Black 4.2L I6 4X4
do you have a link to where i can buy these ?
- Justin
NorthEast Chapter
Old 09-21-2009, 11:54 AM
Abelcastro1 Abelcastro1 is offline
2004 GMC Envoy SLT XL
Summit White 4.2L I6 4X4
http://www.suspensionmaxx.com
Old 09-21-2009, 11:56 AM
Senior Member
Black 4.2L I6 4X4
Originally Posted by Abelcastro1 View Post
thank you. looks like a wickid easy install. im gettin squeaks hitting any sort of bumps and i think its the bushings but id replace the hole link instead cuz its a lil rusty.
- Justin
NorthEast Chapter
