When brakes are applied it squeaks - Page 2 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2006 - 2009 TrailBlazer SS Tech > 06-09 SS Brakes, Suspension, Wheels and Tires > Brakes
Brakes Brake repairs/upgrades
Old 03-18-2010, 06:52 AM
nass nass is offline
2007 Chevy TrailBlazer SS (3SS)
Black 6.0L LS2 V8 AWD
There is no dirt from the last time I checked the brake pads. From the last time when I took the pads off I noticed there was a clip type on the brake pad. Is that for anything?
Old 03-18-2010, 06:57 AM
msigler21740's Avatar
msigler21740 msigler21740 is offline
2004 Chevy TrailBlazer LT
Just because you dont see any dirt doesnt mean that there is any. I dont know that the clip on yours is for, I havent put brakes on a TB yet but I have dont alot of brake jobs on others.
Feb 06 2010: 34.5 inches of snow (at once) and drifts higher than my side mirrors and the TB hasn't been stopped yet.
  #13
Old 03-18-2010, 10:28 AM
Ok i have spoke with a chevy technician about the brakes. He said that the brake pad sensor (tab from what I said before) which is what is making the squeaking noise. My question which I should have asked the chevy tech is can you adjust the sensor?
  #14
Old 03-19-2010, 07:37 AM
I figured out my issue... The shim on the back driver side brake pad was gone. No wonder why I am getting the noise I am hearing. Does anyone know of brake pads that wont need shims?
  #15
Old 03-19-2010, 08:45 AM
Wex Wex is offline
Senior Member
2006 Chevy TrailBlazer LS
During very very high humidity I get a squeak on the first and second brake attempts. My pads seems well within spec.
If I drag the brakes lightly for about 1.5 seconds it ends the squeak. Only happens on high humidity. Dew just dripping like crazy off the paint.
I should knock my tires off and take a good look. On other vehicles I had, it would just make them sensitive until they were applied once or twice.
Anyone else live where its 90%+ humidity all night long?
2006 TB-LS 4x4. 4.2, 85K
  #16
Old 03-19-2010, 10:10 AM
joemoto311's Avatar
joemoto311 joemoto311 is offline
Senior Member
2004 GMC Envoy SLT
Carbon Metallic 4.2L I6 4X4
USUALLY when the brakes squeek when you do this, its just because of the type of pads you put on...when you start hearing the noise all the time thats when your down to the metal warning clip(if you or the person doing it reinstalled them)....they do make a gel type thing that you can put on to quiet them but if it really bothers you(it would me) just go buy good pads for the front and replace them....the noise isnt going away because of the way the pads wore down...it puts like an edge on them and thats the noise you are hearing
NOW THIS IS JUST USUAL SITUATIONS....YOU STILL NEED TO CHECK THEM TO MAKE SURE!!!
i have high humidity here and mine only make noise for a second if the vehicle has sat longer than a day...but it goes away before i even leave my neighborhood and its not even loud or really noticeable if you have the radio on even on very low
I recommend replacing the flux capacitor once a year on the 02-04's
  #17
Old 03-19-2010, 12:00 PM
Trailblazer88's Avatar
Trailblazer88 Trailblazer88 is offline
2006 GMC Envoy Denali
Summit White 5.3L V8 4X4
im getting a squeek thats getting to me too. I jsut replaced my rotors and pads about a month ago and just last week it started squeeking... most of the time it does it at lower speed. Was just the drivers side and now i think its both sides. I got a higher quality set of napa ceramic pads ($60) and a sort of midgrade rotor from advance autoparts. I used plenty of the "squeek lube" on the back of the pads.. any ideas? Could a bad set of rotors cause it?
  #18
Old 03-19-2010, 01:44 PM
joemoto311's Avatar
Senior Member
2004 GMC Envoy SLT
did u use a lot of brake clean while and after to make sure u cleaned off all the rotors and pads? try it again....also if the pads weren't "burnt in" before you installed them and u didn't then that's the reason and you might be able to burn them now as long as u haven't already made a normal wear pattern
  #19
Old 04-01-2010, 04:51 PM
Yes I used a lot of brake cleaner. I did noticed that my driver side rear brake pad is missing a anti vibrating clip well missing half of it. Does anyone know where I can buy one at?
  #20
Old 04-01-2010, 05:46 PM
SailorJay451's Avatar
SailorJay451 SailorJay451 is offline
2002 Non-GMT360 Other
Silver Other 4X4
I have this same issue, just replaced my back pads 1K miles ago, dut I don't remember there being any of those shims in the back pads. I'll pull off my tires and check all 4 brakes and maybe clean the rotors and pads as well. Will let everyone know if it works.
New Trailblazer coming soon....just gotta find the right one!
