Hi,
Just wondering if anyone has had this issue. Bulb replaced... checked fuse for left front low beam fine and replaced. High beam works fine. Connectors check no heat issues connections look perfect both for the headlight lamp and the headlight connector module at the base of the light .... any other check points ? thanks for the help. Cheers
Your going to have to do some voltage measurements, starting at the fuse box at fuse #6 and then follow the yellow wire coming off connector C4 contact E2 and going to the left headlight assembly. You may have a broken wire or a problem at the fuse box.
Check solid state relay # 46 in the same fuse box, close to your fuse for low beam. You can switch relay # 45 which is for your engine fan with # 46 and see if your low beam comes on. That was the fix for my 2006 trailblazer with no low beam. Hope this helps. I bought a new on in auto zone.
just and update forgot to let yall know what I found. I traced the power circuit and found the ground wire connection was lost for the low beam. Easy fix ran a new wire all set ! thanks for the advice and help. Cheers
Related Threads
1.3M posts
173.7K members
Since 2004
