Engine coolant runs slightly hotter than normal - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 4.2L I-6 Engine and Drivetrain > Engine Tunes/Mods
Engine Tunes/Mods Performance Engine Tuning/Engine Modifications
Old 06-07-2018, 02:20 PM
TheMadHatter's Avatar
TheMadHatter TheMadHatter is offline
2004 Trailblazer
When I’m driving in the city, normal stop and go, my coolant temp sits right at the half way mark (210). When I get on the freeway however it jumps up anywhere from 10-15 degrees higher. Never overheats though.
I drove it daily about 140 miles round trip (all freeway). Mornings it seemed to be fine. Afternoons coming back it seemed to be running hotter (although not always).
I’m not understanding what the problem could be. It has had a coolant flush within a couple months. Radiator seems to be fine.
Any suggestions or has this happened to anyone else?
ID:	37177   Click image for larger version
Old 01-04-2019, 04:37 PM
Lynch's Avatar
Lynch Lynch is offline
Man put some gas in that thing
Old 01-05-2019, 09:12 AM
NJTB04 NJTB04 is offline
Pewter Metallic 4.2L I6 4X4
Check it with a scanner to make sure it's a problem. Thermostats and coolant sensors usually fail cooler (trucks ~195 degrees, reads 180, for example).
Look for proper coolant level, anything blocking the radiator (leaves), fan operation, etc.
Could be the stepper motor is going bad.
