Rear control arm bushings - replacement part numbers - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Suspension Suspension
Old 04-24-2019, 08:23 PM
madmac66 madmac66 is offline
2007 Chevy TrailBlazer LT
Silver Mist Metallic 4.2L I6 4X4
I just replaced the rear shocks in my 07 TB LT
I noticed the sway bar links were shot so I ordered a new pair.
I was wondering about replacing the control arm bushings while Iím doing all that. I did the fronts (sway links, ball joints, all bushings) last year. I didnít get the pry bar out on the rears yet but if the state of the fronts was any indication the rears will need doing too.
I searched; google, trailvoy, rockauto - for info on parts but could not find any mention.
Can anyone point me in the right direction, or tell me the correct part name, to be searching for.
Thanks
Old 04-26-2019, 12:15 PM
So all I can find while searching is this set from 1aauto of replacement control arms.
https://www.1aauto.com/control-arm/i...1115374&y=2007
Is this a case of the bushings being too hard to replace? Why are the individual bushings so hard to find?
Has anyone pressed the bushings in the rear, or have you just swapped out the whole arm?
Thanks
Click image for larger version
Old 04-27-2019, 08:25 AM
NJTB04 NJTB04 is offline
2004 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 4X4
I think you have to get the whole unit. Don't remember anyone just pressing the bushings in out and in.
Old 04-27-2019, 05:38 PM
Okay. That makes sense I guess. Theyíre pretty heavy looking bushings, and for the cost itís probably not worth the effort
Thanks
Old 04-29-2019, 12:17 PM
supersport777 supersport777 is offline
Black GMC Envoy Denali
Carbon Black Metallic 5.3L V8 2WD
The OEM GM part description is Upper Control Arm/ Rear Axle Control Arm. Here's the page showing this info for your reference https://www.gmpartsprime.com/oem/gm-...-15069837.html
Old 04-30-2019, 07:24 PM
Thank you!
Similar Threads
Lifted Members Sign In... Quest To Find a Number Foosh Suspension 255 09-30-2018 07:14 PM
Lower Control Arm Bushings - Replacement JBar Suspension 4 05-16-2014 06:56 AM
PCM pinout needed tdpisme Engine Tunes/Mods 3 01-01-2011 08:58 AM
