How to: SMAXX "MAXXlinks" sway bar end link installation. - Page 2 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Suspension Suspension
Old 09-21-2009, 12:06 PM
Abelcastro1 Abelcastro1 is offline
2004 GMC Envoy SLT XL
Summit White 4.2L I6 4X4
Originally Posted by blktblazer04 View Post
thank you. looks like a wickid easy install. im gettin squeaks hitting any sort of bumps and i think its the bushings but id replace the hole link instead cuz its a lil rusty.
No problem, I'm digging these as good replacements for my Moog ones that I replaced about a year ago, and I think they're starting to clunk and squeak again after I greased them about 4 times already. On the website it says 90 bucks but well worth it if you dont have to service them again for a long time.
Old 09-21-2009, 03:50 PM
MrSmithsTB MrSmithsTB is offline
Super Moderator
Mid-Atlantic Chapter
2002 Chevy TrailBlazer LS
Exactly the idea. I'm not 100% sure, but I think you can buy replacement bushings, which will make a huge difference in the long run.
  #13
Old 09-21-2009, 05:49 PM
blktblazer04's Avatar
blktblazer04 blktblazer04 is offline
Senior Member
2004 Chevy TrailBlazer LS
Black 4.2L I6 4X4
what did you use to grease them with? WD-40, PB blaster, white lithium grease ?
- Justin
[B][COLOR="Blue"]North[COLOR="Gray"]East [COLOR="Red"]Chapter[/COLOR][/COLOR][/COLOR][/B]
  #14
Old 09-21-2009, 10:33 PM
Super Moderator
Any of those work. But only until it is washed/ rubbed away. The only real cure is to replace them.
  #15
Old 09-22-2009, 12:03 AM
Senior Member
Black 4.2L I6 4X4
yea im going to replace them if grease works then ill know for sure
- Justin
  #16
Old 09-22-2009, 07:48 AM
The moog replacement ones have zerk fittings, I just used good old black grease. But there's something I don't like about the moog ones, they have rubber cones that go around the inside of the elbow links and do not completely seal the joint like the oem ones. So the grease always leaks out of there over time, and I guess there is also the chance of water contamination, or dirt.
  #17
Old 09-22-2009, 08:20 AM
Vayne's Avatar
Vayne Vayne is offline
2004 Chevy TrailBlazer LT
I put a pair of these on the front a couple weeks ago, the front feels tighter and no noise at all and i've been driving it a little rough.
  #18
Old 03-18-2010, 10:29 AM
Vayne's Avatar
The autozone rear swaybar links went bad, the rubber cracked and came all the way off. Time to put suspension maxx links on the rear.
  #19
Old 05-02-2010, 10:08 PM
grandntl's Avatar
grandntl grandntl is offline
2006 GMC Envoy Denali
Liquid Silver Metallic 5.3L V8 4X4
you guys still running these maxxlinks? I guess they are the best?
Just wondering, as I just did mine with OEM replacement GM parts. Got them from the dealer FREE or I would have bought them... but still have a little clunking happening. guess it may be the rear, or something else.....
Dealer with the hand shake here screwed me over......
  #20
Old 06-26-2010, 03:24 PM
CHINGON81's Avatar
CHINGON81 CHINGON81 is offline
2003 GMC Envoy SLE XL
Silver Green Metallic 4.2L I6 2WD
installed today them today
I installed the Smaxx front (666f's). i had issues with the way they fit, they did not just slide in. I had to use a bar to lift the sway bar up in order for the links to fit. was i supposed to do that. i installed as the instructions showed. will i have problems if i did this? if i effed up what can i do to fix?
Click image for larger version
[COLOR=darkslateblue][COLOR=blue]2003GMCEnvoyXL[/COLOR] [/COLOR][COLOR=red]2005PontiacG6[/COLOR]
