2006 TBSS 2WD Rear Pinion Seal Leak - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2006 - 2009 TrailBlazer SS Tech > 06-09 SS Engine and Drivetrain > AWD Drivetrain
AWD Drivetrain AWD repairs & problems
Old 12-30-2012, 11:22 PM
c72lt1 c72lt1 is offline
2006 Chevy TrailBlazer SS
Imperial Blue Metallic 6.0L LS2 V8 2WD
Replaced a leaking rear differential pinion seal. Reused the crush sleeve with properly setting the preload with beam type inch pound torque wrench.
Still have a leak at the seal. Looks to be coming from the shaft to seal area because it is slinging it under the body. Not just leaking to the ground as if it was the seal to the case leaking.
Any ideas on possible causes. Having to rely on the dealer to solve this concerns me.
Thanks Forum
JB
Old 12-31-2012, 12:38 AM
mrphoenix80's Avatar
mrphoenix80 mrphoenix80 is offline
2006 GMC Envoy SLE
Graystone Metallic 4.2L I6 4X4
Did you check the sealing surface on the yoke? If it has a groove in it then the seal can not hold proper tension and will still leak. The only way i know to fix this is a new yoke. Also check the pinion for play up and down, left or right a worn bearing may cause a leak also. And that repair means replacement bearings. Good luck to ya
Old 01-01-2013, 12:39 PM
Thanks for the response. One other question. What is the allowable movement of the axle in & out. With all in new condition will the axle be able to be pulled and pushed in and out?
Thanks
JB
Old 01-01-2013, 07:28 PM
2006 GMC Envoy SLE
The pinion should have no movement other than twist. But the axle shaft to the wheels will have some in and out. I dont have a spec but something like 1/8 inch or so is normal.
