Steering wheel movement - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Brakes, Suspension, Wheels and Tires > OEM Issues
OEM Issues OEM Repairs & Problems
Old 04-12-2008, 09:49 PM
rubberman's Avatar
rubberman rubberman is offline
2004 Chevy TrailBlazer LS EXT
Dark Gray Metallic 4.2L I6 2WD
i have the steering wheel movement while driving. its not a vibration but the left, right movement. is that a front end alignment issue?
2004 TB EXT I6 CAI, PCM4Less PCM, Resonator delete, Kuhmo KL51
Old 04-19-2008, 12:04 PM
brendanpower's Avatar
brendanpower brendanpower is offline
Senior Member
2007 Chevy TrailBlazer LT
Moondust Metallic 4.2L I6 4X4
Depends how much Steering Wheel Play you have. There is always some, but if your mentioning it, it must be alot. 75% of the time its steering linkage play, the other 25% is Steering Rack/Box Play. In either case, an alignment wont fix the problem without first finding the source of the movement.
Brendan,
PCMFORLESS Tune, CAI, HID's, PIAA's, Mirror Signals, Glasspack & Tip
Old 04-20-2008, 02:00 AM
LMMJ's Avatar
LMMJ LMMJ is offline
2002 Chevy TrailBlazer LS
Indi-GO Blue Metallic 4.2L I6 4X4
a left to right movement, when you let go of the wheel, is most likely in the tires.
Luis
Old 10-13-2008, 09:41 AM
sleeper22 sleeper22 is offline
2006 Chevy TrailBlazer SS
Summit White 6.0L LS2 V8 2WD
Did you ever find the cause of your play in the steering wheel? I took my truck in 2 weeks ago for an alignment. Then the steering wheel wasn't straight. I took it back and then the steering wheel was still not straight and now there is a lot of play in the wheel too. I took it back again and they replaced the steering shaft? The non-straight wheel and the play in the wheel is still there. I just took it back this morning and they are telling me it's because my truck is lowered. This is BS. I didn't have any of these problems until they aligned the truck. I am pissed and they are just screwing with me. I plan on contacting the better business bureau!
I just want to go faster. Is that so bad?
Old 10-14-2008, 08:48 PM
LMMJ's Avatar
well, an alignment won't cause play in the steering unless they left the lower control arm adjustment bolts loose but other problems would have arised. I've done a bunch of re-alignments to my truck after all the wheel/suspension changes and have no play in the steering. However, they could have over-torqued the jam nuts on the tie rods causing them to twist and make the socket widen slightly but highly unlikely considering the PITA design of our tie rods (you need 2 wrenches to lock the jamnut)
Luis
Old 12-30-2017, 12:14 PM
kmand kmand is offline
2008 SAAB 9-7x
Dark Gray Metallic 4.2L I6 AWD
I am also having a dead zone steering off center, mine seems to be the u-joint in the tilt column. I will probably end up having to replace the entire column if I cannot gain access to the u-Joint.
Similar Threads
Problems with the steering wheel control BUC NASTY OEM Issues 11 04-13-2008 01:44 PM
Steering Wheel Upgrade FJPTB Interior 0 04-03-2008 11:41 AM
Steering wheel vol and Sony remote pctravel Audio and Electronics 5 02-29-2008 06:23 PM
Serious Help! Cant pull out the steering wheel BUC NASTY Interior 12 01-21-2008 04:11 PM
Steering Wheel Control Not Functioning Sims Envy Audio and Electronics 5 03-11-2007 12:10 AM
