Window switch curiousity - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > General TrailVoy Discussion > Audio and Electronics
Audio and Electronics Discuss car audio, video, navigation, alarms, and other electronics here.
Old 05-15-2019, 02:47 PM
Bigbobby13 Bigbobby13 is offline
So my passenger window switch is shorted out because of water. Instead of buying a new one or used, and pay to have it programmed, could I wire the passenger window motor to the passenger window switch on the driver side control panel and have it roll up and down with that switch?
Old 05-15-2019, 03:21 PM
setauketjeff's Avatar
setauketjeff setauketjeff is offline
Silverstone Metallic 4.2L I6 4X4
Water Damaged Window Switches
If it were the driver's side, it would be under extended warranty, as these were recalled. No recall that I know about the passenger side, but, there may be a secret one. I'd call your dealership before any rewiring. If not, then I might just go the ebay or rockauto route.
Old 05-15-2019, 03:34 PM
First of all, the actual switch does not control the window motor directly. The electronics in the door module does that. And if you are thinking of adding the passenger window motor wiring to the driver's window motor wiring, the electronics can not handle extra load of two motors. Just bite the bullet and buy a used one on Ebay or go to a salvage yard.
BTW I don't think the door control modules require programming.
Old 05-15-2019, 03:36 PM
Everything I've read says it has to be programmed or hooking it up will result in security mode, making all the dash gauges and lights act crazy
Old 05-15-2019, 03:47 PM
Dealer said $120 to program it even if I but it from them.
Just want to roll down the window, other than dealer programming, just looking for another option.
Old 05-15-2019, 05:37 PM
Seriously, find another GM dealer. Maybe a bad Yelp review would help get you the proper attention. If the mod does need programming, and I tend to doubt it too, it would take less then 10 minutes, and that includes taking the computer out of the toolbox, walking it over to the car, programming, and then walking back to the tool box and putting it back. And these dealers wonder why we hate them! Just think if they said sure, put it in your self and if you have an issue, call first for a time to bring it over and the floor manager will reprogram it for you for $25. Think about how many people you would tell. And since you do your work yourself, you're probably a "car guy" who's neighbors, relatives and friends all come to for automotive advice. Idiots!
Tailgate (swing, drop) Pressure Switch Repair e-iowa-o General 31 05-31-2017 05:01 PM
Window Switch malfunction L0G1K General 3 12-03-2015 10:01 PM
2007 tb lt passenger window switch joe70ss General 4 09-14-2015 03:45 PM
window switch recall released 07TB General 0 03-10-2013 12:31 PM
Can the window switch cover be swapped? mubai General 9 05-12-2010 08:29 PM
