No power to trailer plug - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 04-13-2019, 12:05 PM
agff agff is offline
2004 Chevy TrailBlazer LT
Summit White 4.2L I6 4X4
Hello, 2004 EXT, I6 newer to me.
I have no power at all to the trailer plug at the rear bumper.
Nothing with test light at any lead.
Unplugged connector behind it and tested, no power there either.
Checked all fuses related to trailer lights in the engine compartment, none blown and have power to the respective fuse socket in the bank as it should be when the fuse was pulled out to look.
Any ideas on where to look next?
Is this some module issue not allowing power for the lights to these circuits?
Thanks.
Old 04-14-2019, 06:27 PM
jroden jroden is offline
To get the charge wire to work, you have to hook up the little wire hanging loose next to the front of the relay and fuse box under the hood, driver side. There is a stud with a nut on it that supplies 12 volts
Old 04-15-2019, 12:29 AM
Thanks, I had seen that mentioned before, but my issue isn't the charge wire - it's all the light going to the trailer plug are dead. Stop/turn/tail - I got nothing.
Old 04-15-2019, 06:38 AM
looking at the wiring diagram, they note something called the "park LP relay" that sends power through fuse 42 at "fuse block rear" to the trailer plug which looks like it lives under the seat second row drivers side,
Old 04-15-2019, 08:13 AM
contents of that fuse box
https://www.youcanic.com/guide/fuse-...azer-gmc-envoy
Similar Threads
Spark Plug (Coil-On-Plug) Boots at RockAuto.com! RockAuto RockAuto 0 01-12-2017 02:23 PM
[SOLVED] swap manual for leather power seats 05 trailblazer LS tahoeguyz81 The 02-09 "How-To" and DIY Section 1 11-16-2016 09:32 AM
[SOLVED] trailer power GARYMAG The "How-To" and DIY Section 2 06-30-2013 12:11 PM
TBSS Trailer Plug to 4 way flat trailnablaze Towing 9 11-10-2011 07:07 PM
Trailer Electric Connector 7-pin galbertsprint Towing 3 11-26-2007 11:42 PM
