With AWD you have to change all 4 tires at once, correct? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Brakes, Suspension, Wheels and Tires > Tires
Tires Tires
Old 01-17-2007, 01:26 AM
skipfrancis skipfrancis is offline
2005 Buick Rainier
5.3L V8 AWD
Question With AWD you have to change all 4 tires at once, correct?
I'm new to AWD and its on this '05 Rainier AWD V8 we have.
I could get by I think with just changing the 2 front tires P245/65R-17
Michelins Cross Terrains at $190 tire + tax.
But I heard with AWD you have to change all 4 at the same time.
Is that correct?
If it was summer the tires have enough tread (44K miles), but since its winter I thought more tread on the fronts would be better for braking, etc.
Thanks for the help.
Old 01-17-2007, 01:27 PM
MrBigStuff MrBigStuff is offline
2005 Chevy TrailBlazer LS EXT
Summit White 4.2L I6 4X4
Tires
The tires all need to be within a certain range of diameter to avoid wear on the system. Now if you punctured one and couldn't repair it, you could buy one new tire and have them shave it down to match. It doesn't make sense to do this in your situation.
One other point- it seems counterintuitive but the better tires should go on the back. It helps for maintaining control in manuevering. You can check other sources to confirm. I think tirerack.com has good explanation of the situation.
Old 01-17-2007, 03:08 PM
2005 Buick Rainier
5.3L V8 AWD
Thanks MBS...
I went to Tire Rack as you suggested.
Great tech article on AWD and tires swaps.
Skip
Old 01-19-2007, 12:37 AM
Silver Ecstasy's Avatar
Silver Ecstasy Silver Ecstasy is offline
2007 Chevy TrailBlazer SS
Summit White 6.0L LS2 V8 2WD
Can you post article?
Old 01-19-2007, 02:55 AM
FAMU92's Avatar
FAMU92 FAMU92 is offline
Imperial Blue Metallic 6.0L LS2 V8 AWD
Talking Article Link: Changing AWD Tires
http://www.tirerack.com/tires/tirete....jsp?techid=18
[SIZE="2"]Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind. ~ Dr. Seuss[/SIZE]
Old 01-19-2007, 09:01 AM
Spong's Avatar
Spong Spong is offline
TrailVoy Guru
2006 Chevy TrailBlazer LT
Zaino Shined Red Jewel 5.3L V8 4X4
AWD, FWD or RWD, regardless of which wheels do the driving, changing the tires 2 at a time is a bad habit that you don't want to ever start! With proper care & rotation, you should be able to wear the full set down evenly.
Old 01-19-2007, 12:13 PM
MTPockets's Avatar
MTPockets MTPockets is offline
4.2L I6 4X4
If you want maximum safety, you'll want 4 tires with the exact same characteristics. You can get by with changing tires in pairs [one axle at a time] on a FWD or RWD vehicle, I've done it many times. I try to avoid it now. A couple hundred bucks over ~3yrs is nothing.
Joel
2005 Trailblazer LS 4x4, summit white. Adds: Ventshades and LOTS of extra adhesive added for durabilty.
Old 01-19-2007, 05:47 PM
Dave's Avatar
Dave Dave is offline
2006 GMC Envoy Denali
Red Jewel Tintcoat 5.3L V8 4X4
I know Audi's Quattro system was extremely picky about having tires that are worn differently on the car. I'm sure GM's AWD system cares but probably not as much.
I agree your tires should wear out evenly with proper rotation.
2009 GMC Yukon XL Denali AWD (replaced 06 Envoy Denali)
2007 Chevy Impala SS, 5.3 (replaced Totaled 03 TB EXT)
2008 Chevy Corvette 4LT (my toy)
Old 01-19-2007, 11:15 PM
Pairs
Here's the other article on which axle should get the new tires if only one pair is replaced: http://www.tirerack.com/tires/tirete...currentpage=18
Old 01-22-2018, 08:45 PM
debbied6000 debbied6000 is offline
2006 GMC Envoy Denali XL
White 5.3L V8 4X4
I have an 06 Envoy denali. I blew out a tire and was told the that side wall is gone and cannot be fixed. Les Shawab told me that I needed to by 4 new tires because the tread needs to be the same. The current tires were brand new when i purchased the vehicle last July. I've put close to 7000 miles on them since purchased. Do I really need to buy 4 new tires. It's not AWD.
Similar Threads
2WD or AWD? ssblaze General 7 12-13-2006 09:17 PM
Atco on Street Tires TonyGXP Racetrack Results 18 12-12-2006 11:11 AM
New tires for stock 17's, have 22's for summer. jkeating86 Tires 2 08-26-2006 03:37 PM
Cupping Tires Bulldog Tires 6 07-03-2006 10:10 AM
what mileage did you get from your stock tires? rbarrios Tires 17 04-14-2006 01:40 PM
