Whelen install plus other goodies.. - Page 2 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > General TrailVoy Discussion > Emergency Equipment
Emergency Equipment For Emergency Personnel and Whackers.
Sister Site- Emergency Equipment Forums
If you are interested in Emergency & Public Safety Equipment, please check out our sister site @ eLightbars.org
Old 10-05-2009, 10:25 PM
rmoni317 rmoni317 is offline
2008 Chevy TrailBlazer LT
Summit White 4.2L I6 4X4
Yeah man thanks to help from you
And I used the original suction windshield mount took out the suction cups and cut the bracket to be even straight across.. to mount it to the window I used interlocking adhesive strips I will get you a direct name because the velcro doesn't work. I ran the wire in headliner down the side door panel grounded wire and ran the power line to center console fuse panel I installed for my power.
And thank you I am great at all the wiring but like I said in the emails I cannot take the PITA trailblazer apart but came out okay in the end I will be adding the front highbeam flashers, rear taillight flashers and rear ceiling mounted lights this weekend so check back.
Hope all is well. Thanks again.
-Ralph
Old 10-06-2009, 07:02 AM
SilverUnicorn's Avatar
SilverUnicorn SilverUnicorn is offline
2006 Chevy TrailBlazer LS
-Ralph
Thanks Ralph! I will have to look into that option for my Talon. Would the tape be the 3M Dual Lok tape? It's the same thing they use for the wavy bumper fix on the TB. Good stuff!
Glad I could help you out, even if just a little bit. Looking good!
[CENTER]
[/CENTER]
  #13
Old 10-07-2009, 12:23 AM
Okay sorry it took so long been busy... I purchased the fasteners from Radio Shack and they are the (Dual-Lock - Hi Temp / Hi Strength Superlock Fasteners) I don't know if you have EZ-Pass but its just like the window fasteners they send out... the velcro fasteners didn't work I tried doing it that way Saturday and when I was installing the strobes Sunday the Talon fell off window. So far so good with the Superlock Fasteners if it ever comes down I plan on putting it in the same spot and installing it with the radio mount steal that is flexible enough to bend and attaching it to the visor mounts .. Hope its works for you good luck.
Ralph
  #14
Old 10-07-2009, 03:05 AM
Devilz311's Avatar
Devilz311 Devilz311 is offline
2004 Chevy TrailBlazer LS
Onyx Black 4.2L I6 4X4
Nice!! The console looks great! I was hoping you wouldn't leave the wiring all over the place...
  #15
Old 10-07-2009, 04:11 PM
Definitely not ha that would drive me insane I like keeping my car clean and good looking. I used Plexiglass, drilled the holes, painted it to match the center console and then put some brackets and a little hot glue Installing taillight flashers tonight should be done and have some pictures soon.
  #16
Old 10-16-2009, 10:47 PM
ksoldani's Avatar
ksoldani ksoldani is offline
2003 Chevy TrailBlazer LTZ
VERY clean, great setup.
As far as mounting an inverter, I mounted mine under the rear seat and ran a small power strip sitting in the back to plug accessories in. Not sure if you'd have room or not in the console? I'd be concerned about cooling..
I'll get pictures of where the inverter is mounted in my truck this weekend so you can get an idea.
- Blue Township Fire/Rescue - KD0LDK - 911 Dispatcher -
'03 TB - 150k
  #17
Old 10-17-2009, 05:10 AM
I dont know if you can see in the picture but not only did I leave an inch or so in between the scanner for louder volume I also did it for cooling... honestly unless I am at a call the trip to the firehouse is like 5 minutes or less so it shouldn't be getting so hot anyways but would love to see how you mounted yours I am thinking about relocation so I could get a little storage space in the center console back. Even considering moving switches to where change is and hiding a main switch near the fog light. I don't know though haha kinda like my set-up now.
  #18
Old 10-17-2009, 09:13 AM
Loverotties Loverotties is offline
2002 Chevy TrailBlazer LTZ
Looks great! which one is for the missile launcher?
  #19
Old 10-17-2009, 06:56 PM
Having got that installed yet.. so far just the mudslick, ejector seat, thumb tacks dispenser, beer cooler and turbo boost. Thanks though.
  #20
Old 10-28-2009, 09:27 AM
Diablo03's Avatar
Diablo03 Diablo03 is offline
2003 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 4X4
anything on the rear center mounted light?
[B]Midwest Chapter MO member[/B]
need 1G DSM parts?....
