$5.00 "fix" for air ride compressor.... - Page 13 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Brakes, Suspension, Wheels and Tires > OEM Issues
OEM Issues OEM Repairs & Problems
Old 12-05-2017, 07:59 PM
stainlesscycle stainlesscycle is offline
rainier Buick Rainier
Black 4.2L I6 AWD
mcamster-carr has the parts..
i know this is an ancient thread but: macmaster-carr has everything you need. ships fast and cheap. part numbers below descriptions.
wye 5/32
5779K42
or
tee 5/32
5779K32
if you want to get fancy ( kept my compressor in line, 2 tees and a wye):
schrader valve
8063K31
adapt schrader valve to 5/32 push fit
7880T163
5/32 line (25') 220psi
5112K62
then you can relocate the airfill anywhere you want.
you can also tee in a pressure gauge (standard 1/8 thread) with
5779K227
or on the end
with
5779K125
theses are all $5 parts...
Old 01-11-2018, 01:57 PM
bdlz bdlz is offline
2003 GMC Envoy SLE XL
Carbon Metallic 5.3L V8 AWD
I'm so glad I found this thread! I just had the compressor quit on my Envoy - and the price for a compressor is now $600-$800 for a refurbished one.
Once I got the compressor off, the fix was easy... of course it took 4 hours because the spare tire hoist froze up after lowering the tire part way down - that was the hardest part of it.
It has been over 24 hours and so far it's holding pressure, better than it was before the compressor failure (guess it wasn't a leaky spring after all).
Now I just need a new tire hoist.
  #123
Old 01-16-2018, 10:45 AM
Spoke too soon! It held air for a little over 24 hours. Now it inflates, but goes goes down after a few minutes. I'm hoping it's just a loose air line, but haven't had the chance to work on it due to the weather.
Anyone have issues with the fill valve leaking?
  #124
Old 12-26-2018, 09:01 AM
MissEnvoy MissEnvoy is offline
2003 GMC Envoy SLT XL
Carbon Black Metallic 6.0L LS2 V8 2WD
Originally Posted by MissEnvoy View Post
24 hours after adding gasket maker the air pressure still at 61 psi. I'm installing the Envoy air compressor back.
Just to make sure I'll be adding a bit of gasket maker to the air compressor air hose fittings too and letting it dry/cure for a day before I turn on the SUV.
BTW: I used gasket maker also on the brass inflator valve with the 5\32 and that is how I stop the leak there.
1. pulled the hose
2. with a small pin added gasket maker
- add it just above the small black O-Ring
- add a bit around the push in fitting that you pulled out to get to the O-Ring
- add a bit around the hose - not the tip, but about the area where it will be pinned by the push in fitting.
- push in the hose - let it dry for 1 hour or 2
- put just 2 psi to push the gasket up - let it dry/cure for 24 hours - check for leaks
- after 24 hours - now you can pump up the air
Now is just a matter of time and see for how long this gasket will hold.
Another fix should be to change the small O-Ring, but I was not able to find it and don't know the exact size. The brass air inflator valve has 1 O-Ring and the air spring 2 each, the compressor uses compression brass O-Rings.
And another BTW: I clean up the check valve inside the compressor, the bottom had some build-up and I think it might not allowed the valve to sit perfectly flat so I did a bit of cleaning and then put everything back. The two screws were a pain to get out since they had red tread locker (added the same stuff)
I'll keep you posted. (If the air compressor ever fails I know I can install the tee union back )
Update: 2/14/2013 - Air is holding, Envoy was level this morning - I'll keep monitoring, I'll say the air leak is fixed.
Alright I'm back with the same problem after the 2013 FIX - WOW almost 5 years
I'll be doing the same thing all over again since the pump still works after all.
Just adding my 5 cents since I know a shop will try to break your wallet.
  #125
Old 01-12-2019, 04:52 AM
Sorry to bump this one up, but I promised to keep post updated.
Well I'm 5 years older and don't have a garage anymore so I took the Envoy to the mechanic who quoted me for $1800 to replace the air pump and no guaranty that it will be a fix they said, they refuse to do the $5 fix even that I offered to pay $200 for the 30 mins labor.
Armed with the knowledge of the $5 fix on this forum I went to a mechanic I found near an Autozone and for $50 he did the fix in about 30 minutes.
I guest my first fix 5 years a go was some how a very good quality job or the damage was less because the new fix in about 10 or 12 hours psi went from 65 to 55 lost about 2" high from fender to tire.
I forgot to ask the mechanic to put gasket maker on the "T"
For the moment I'll be pumping air every morning to 65 psi, but I'll be making the transition to metal springs due to the lock of [I can't work on the car my self anymore] a place to do fix it my self.
So for those out there still coming across this post, my advice is to use the gasket maker and the air will hold much longer. Also check your ride high sensor my was broken, don't know if they did that at the first shop where I got quoted for $1800 or the towing. The mechanic at the Autozone found it and let me know about it(with the broken ride high sensor the pump definitely will not turn on because the sensor is extended all the time).
I'll buy the springs and will bring the Envoy to the same guy to get them installed.
  #126
Old 03-05-2019, 06:57 AM
robertallinson robertallinson is offline
Does it hold 50 psi fairly well? I figured it would make the drive a little stiffer if it were at a constant level at all times. Good luck with it though. 5 bucks sounds a whole lot better that almost 500. Good job.
Similar Threads
Air ride compressor runs a lot.. redz71tahoe OEM Issues 1 04-19-2008 10:53 AM
