Quad Tail Lights? How-To Inside - Page 10 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2006 - 2009 TrailBlazer SS Tech > 06-09 SS Appearance > Exterior
Exterior Exterior repairs/modifications
Old 05-29-2010, 01:31 AM
Another BlackSS's Avatar
Another BlackSS Another BlackSS is offline
2006 Chevy TrailBlazer SS (3SS)
Black 6.0L LS2 V8 AWD
so do you have to do the circuit board mod before you add the relays? or can you just wire up the relays?
Old 05-29-2010, 01:46 AM
SS-LS2's Avatar
SS-LS2 SS-LS2 is offline
2008 Chevy TrailBlazer SS
Red Jewel Tintcoat 6.0L LS2 V8 2WD
the circuit board mod is just for the quad parking lights
the relay mod is for the quad brake and turn light
  #93
Old 05-29-2010, 05:38 AM
Thanks for the quick response. Im gonna try to get this done over the weekend. I could care less about the quad parking lights, I just want the quad turns and brakes.
  #94
Old 05-29-2010, 08:04 AM
jsprewell's Avatar
jsprewell jsprewell is offline
2002 GMC Envoy SLT
Magnetic Red Metallic 4.2L I6 2WD
The term "Parking Lights" is kinda misleading. While yes, they are parking lights, they are mainly used as nightime running lights (when you drive your TB at night). So it's a good idea to do this mod as well.
  #95
Old 05-30-2010, 02:30 AM
I know what parking lights are. I just want the quad brake and turns due to the fact that I am using LEDs and I dont feel there is a big diff in the brightness of them when I have the lights on and brake. I just want to prevent someone from not seeing a diff when I brake at night (not that the 3rd brake light isn't enough) and rear end me.
  #96
Old 06-03-2010, 12:35 AM
so I got around to doing this last night. I used four pin relays instead of five pin. It didnt work is it because of the four pin?
  #97
Old 06-08-2010, 09:03 PM
SloSS SloSS is offline
AWD SS Chevy TrailBlazer SS (3SS)
Imperial Blue Metallic 6.0L LS2 V8 AWD
yes need 5 pin relays
  #98
Old 06-30-2010, 09:17 AM
So I got these relays wired up for quad brakes and turns......I got hyper flashing while using my T/S and applying the brakes, how do you correct this??
  #99
Old 07-02-2010, 01:04 AM
SS-LS2's Avatar
did you use the resistor on the T/S wire? see post #87
  #100
Old 07-20-2010, 03:53 PM
does it really matter which one you use? Im not running all LEDs yet but I installed the .15 Ohm resistor and everything works great. Thanks for the help
