Front Differential Seal - Page 11 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 08-01-2016, 07:36 PM
Capt Nachos Capt Nachos is offline
2003 Chevy TrailBlazer LTZ
Summit White 4.2L I6 4X4
Getting that Diff Seal out...
Changed out my Driver(left) side CV axel this weekend. Was expecting it to be a more of a pain than it was. One of the sticking points discussed was that Diff Seal. After trying a couple different methods talked about on here I found the easiest way for me to get it out was with a claw hammer. Took about 20sec at most. Just maneuver the hammer in there so you can get some leverage then get the claw/tines just under the lip of the seal with the head resting on the opposite side of the opening. Give a solid steady yank and it should pull out one side. Spin the hammer around and do the same on the other side and by the third time it should pop right out.
I would post pics but it's not letting me.
Old 09-12-2016, 06:50 PM
leonpiper69 leonpiper69 is offline
2002 Chevy TrailBlazer LT
Emerald Jewel Metallic 4.2L I6 4X4
Just changed my left hub bearing 2 days ago and today I did the CV axle........still hums at 30+ mph. So now I am going to look at the driver side. I hope it's just the axle bearing and not the whole diff.
I wish I had known about this seal before today. I would have changed it while doing the axle. There is a small leak but not bad so I will do it later.
  #103
Old 09-25-2017, 01:33 PM
aciuca aciuca is offline
Carbon Metallic 4.2L I6 4X4
help to get home
am i able to drive my tb home from work about half hour away with little or no oil in the front diff. with making anymore major damage?
  #104
Old 09-25-2017, 05:40 PM
Schurkey's Avatar
Schurkey Schurkey is offline
New Member
green 4.2L I6 4X4
The grease can be topped-off without even jacking the vehicle up. Turn the front wheels all the way to the left.
I use a long-handled 1/2" ratchet, a long extension, and an 18mm swivel socket. A regular socket and universal joint would work almost as well.
A pint of grease can be poured or pumped into the differential, if you're willing to crawl on your back.
All of this is preferable to driving the unit with little or no grease. OTOH, as long as you stay out of AWD or 4WD, there's little load on the unit. MAYBE you'd be OK. I wouldn't recommend it, though.
I would NOT drive with the differential empty or nearly empty in one of the Trailblazer cousins that cannot be put into 2WD mode.
  #105
Old 09-02-2019, 06:40 PM
paddy paddy is offline
New Member
2002 GMC Envoy SLT
Great thread; made seal replacement relatively easy - Thanks All! However, now that seal is in, having a tough time getting the axle (driver side front) to seat. Is there a trick to re-installing the thing? Can a rubber mallet be used on the hub end of the half shaft assy.? The factory manual just says to push it in. I've pushed and pushed, it hasn't seated. Thanks.
  #106
Old 09-02-2019, 07:07 PM
Schurkey's Avatar
New Member
green 4.2L I6 4X4
Any chance the differential side gear is out-of-position because the driveshaft or axle shaft(s) rotated?
  #107
Old 09-03-2019, 01:20 PM
New Member
2002 GMC Envoy SLT
Thanks for reply. I locked it in 4WD to feel splines lining up and whacked it with a mallet. Now together, will test drive today.
