Key fob hidden button ? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2006 - 2009 TrailBlazer SS Tech > The 06-09 SS "How-To" and DIY Section
The 06-09 SS "How-To" and DIY Section Threads on Do-It-Yourself and How-To goes here.
Old 03-09-2019, 11:37 AM
Scott Branson Scott Branson is offline
I have a 2007 Trailblazer and I decided to take my key fob apart and give it a good cleaning to get rid of a few years worth of gunk. While I had it open for cleaning, I decided I wanted to separate the rubber button thingy from the circuit and clean up the actual contacts...in the hopes that it might help with the range and the fact that sometimes I have to try a few times with both the lock and unlock buttons before they do anything...although the emergency button always work even if you barely touch it.
Anyway, when I pulled the rubber cover off I noticed that underneath, it actually has four contact pads on the circuit, although the fob only has three buttons. I was wondering if anyone else had noticed this, and was really curious if anyone knew what that unused fourth contact pad might do, if anything.
Old 04-07-2019, 09:49 PM
BJohnson-03TB's Avatar
BJohnson-03TB BJohnson-03TB is offline
from what i understand these key fobs are widely used, since the 4th button wasnt needed in our situation they just werent used. if you had another vehicle they used the same model key fob, you most likely could reprogram it to that vehicle and use the 4th button. just my
Old 04-08-2019, 09:10 AM
TB-Al TB-Al is online now
It appears that the 4th button is to open the trunk. MYT3X6898B is the correct FCC ID number. https://www.ebay.com/itm/New-Replace...5.c10#viTabs_0
Alarm Key FOB Trailblzr03 The 02-09 "How-To" and DIY Section 5 02-20-2018 12:58 AM
[SOLVED] Key Fob Programming jamcomp The 02-09 "How-To" and DIY Section 11 08-08-2016 09:52 AM
Key Fob Help gtiplus General 6 03-03-2010 05:56 AM
Key fob problem bcuk General 1 07-15-2009 09:37 PM
Key Fob question thouk Interior 11 11-01-2005 11:47 AM
