Tires for 20x8 wheels... - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2006 - 2009 TrailBlazer SS Tech > 06-09 SS Brakes, Suspension, Wheels and Tires > Tires
Tires Tires on your TrailBlazer SS
Old 06-10-2006, 12:40 AM
TBlazin7 TBlazin7 is offline
Hey guys,
I've searched and come up with no definate answer so I'll give it another shot. Just wondering if anyone has run a 275/45/20 tire on their SS wheels or any other 20" wheel with an 8" width? Only reason why I ask is because everywhere I look, the recommended wheel width for these tires is 8.5 - 10. Looking at eventually getting some SS wheels and didnt know if I should just stick with a 255/50 tire or if I can get away with using a 275/45 without any problems with mounting, rubbing, and such??? Any help is appreciated! Thanks guys!
Old 06-10-2006, 01:34 AM
Foop Foop is offline
they can be put on a 20x8 but it won't look right IMO. the side wall will pull in slightly. They will be a bitch to mount as well. You can get thrm on an 8 inch wheel though.
Old 06-10-2006, 02:02 AM
Thanks Foop for the reply. My only other consideration I guess would be a 265/45. I've been using a tire calculator and those are the only 3 sizes that I have found to stay close to the height of the stock 17's I have now but using the 20 inch rim. I know I definately dont want to go any taller than they are now but also dont want to sacrifice ride quaility or get to low of a tire so I dont damage a rim if I hit a pothole or something. Dont know what to do...
Old 06-10-2006, 02:20 AM
265 45 would be my choice. If you are that concered investigate you options in that tire size more. Some of the lower profile tires have 5 and 6 plys. Also I believe toyo has low profile SUv designed tires. Check out tirerack dot com. I have been thinking about going to a 265 45 in the rear just a lil wider. good luck
Old 06-10-2006, 12:03 PM
Can anyone else confirm that a 275/45 will work OK on the 20x8 SS wheels because I can get a super deal from a buddy of mine on some Bridgestone Duelers...any help is appreciated...thanks!!
Old 06-10-2006, 02:56 PM
TBSSTony TBSSTony is offline
2006 Chevy TrailBlazer SS (LT)
Black 6.0L LS2 V8 AWD
I saw a 275/45 put on an 8" wide rim on Horsepower TV a while back. Looked great. You'd think they'd be careful recommending combinations that are unsafe. I'll be very tempted to go 275/45 when my stock tires wear out.
Ricers...It's what's for dinner!
Old 12-02-2012, 08:24 AM
eagle845 eagle845 is offline
2008 Chevy TrailBlazer SS (3SS)
Black 6.0L LS2 V8 2WD
I just put 275/45/20 on my SS and have no clearance trouble.
Good luck
Tires dry rot/cracking ericharman2 Tires 6 01-27-2007 11:07 AM
Wheels and tires for Test & Tune nights Bob B Rims 6 09-05-2006 08:23 PM
Wheels And Tires For Trailblazer Or Envoy Deuce_AK Exterior 4 08-16-2006 04:23 PM
New 20" Wheels - Tires AirManFL Pictures and Videos 23 03-08-2006 12:58 PM
wheels, tires and lifts Earthpig Rims 18 08-25-2005 08:56 AM
