P0526 PLEASE help - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 05-19-2019, 02:08 AM
Cuvkiller's Avatar
Cuvkiller Cuvkiller is offline
P0526 PLEASE help
Keep getting the code back, its for a fan clutch circuit. Things I've replaced/ done got acdelco clutch with sensor, replaced fan clutch connector with a new one, replaced relay with acdelco, replaced alternator, coolant temp sensor, thermostat, and I've sanded down amd cleaned all vehicle grounds, I've also looked at the wires and nothing is damaged, I'm legitimately lost on this one, my truck runs incredibly beautiful but the code is driving me crazy. I have the 4.2l envoy with 170k miles on it. Is there something else I can do to fix this damn problem?
Old 06-02-2019, 10:29 PM
05TuckerTB 05TuckerTB is offline
2005 Chevy TrailBlazer LS EXT
Light Pewter Metallic 4.2L I6 2WD
Hey Cuvkiller,
You mentioned sanding down all the vehicle grounds. How many are there and where are they located? Did it take you long? Pics would be great! I think this is at the root of my fuel gauge not working along with a couple of other weird things.
Thanks,
Frank
Old 06-03-2019, 10:53 AM
Oh boy. Put down the parts cannon.
First off, there's a TSB out for cooling fan harness chaffing resulting in P0526, among others. I'll attach a photo. Inspect for this condition, which will likely require removal of the cooling fan and shroud assembly and visual inspection on a bench.
Let's check for powers and grounds.
Pin A (Black) - should have body ground to G103.
Pin B (White) - should have 12v in KOEO.
Pin C (Gray, White trace) - should have PCM ground (DO NOT send 12v down this wire with a test lamp!)
Pin D (Dark Blue) - signal return circuit
Pin E (Gray) - 5v Ref circuit
If the signals above are good, I'd recommend disconnecting at the PCM and the cooling fan and testing voltage drop across Pins C, D, & E. Then checking for shorts between the relay and Pin B.
Also there are two connectors between the PCM and the cooling fan.
Wiring diagram code P0526 cooling fan Paulie710 General 6 06-21-2018 09:06 AM
P0526 code finally solved Envoyproject General 0 07-09-2015 09:22 PM
p0526 code Anniversaryss OEM Issues 1 05-27-2014 01:41 AM
ROUGH Idle and P0526 Code droach1531 General 3 09-27-2011 08:16 AM
Code P0526 mmsmith2032 OEM Issues 8 02-22-2008 08:32 PM
