Pedal Vibration, Rough Idle when Cold - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2006 - 2009 TrailBlazer SS Tech > 06-08 SS General Tech Q&A > General
Old 02-25-2012, 10:47 PM
allin1 allin1 is offline
2004 GMC Envoy SLT XUV
Carbon Metallic 4.2L I6 4X4
Question Pedal Vibration, Rough Idle when Cold
I have a 2004 Envoy XUV, 4wd, 6 cyl. with about 87K miles. When I start up in the morning cold, I have a strong vibration in drive when brakes are applied. I also feel a thump and shudder in the underbody at the moment the engine starts. I can even engage the parking brake, leave in drive and go to my front tires and feel them shake. The exhaust and cat are also vibrating abnormally. The funny thing is when the car idles hot and you drive it for a while the shake disappears and even stopped at light at full operating temp, she idles smooth as glass. I can however feel a gas pedal buzz or vibration upon accelerating. Recently on a trip I also detected a hum at highway speed especially when decelerating. I have changed plugs, CPAS, water pump, serpentine belt, flushed the transmission and changed oil, tran and air filters.
I know about the motor mount issue and thought about it but it does idles smooth when hot, no body vibration felt but still have the pedal buzz. Any advice or direction would be most appreciated. I need to get this addressed before another planned long trip.
Old 02-25-2012, 11:20 PM
shorty's Avatar
shorty shorty is offline
2005 Chevy TrailBlazer LS
Summit White 4.2L I6 2WD
no engine light ? stop by auto parts store and have them hook up code reader
I'm not a mechanic, but i did stay at a holiday inn express last night !
Old 02-26-2012, 12:01 AM
Pedal Vibration, Rough Idle When Cold
NO SES light at all, no codes. Ive also changed the fuel filter. Dealer had it and checked with TECH II. No codes. Thought it was water pump. They changed it and problem still exists.
Old 02-26-2012, 10:36 AM
03TB93's Avatar
03TB93 03TB93 is offline
2003 Chevy TrailBlazer LT EXT
Gold 4.2L I6 2WD
sounds like your engin mounts may be bad? i had to replace mine. does it make a loud vibrationg noise everytime you stop. or everytime u put it in drive? that my guess
Old 02-26-2012, 03:03 PM
But It Idles smooth as silk when hot
The only time it vibrates violently is after a cold start like first thing in the morning. After starting in the morning I can put it in drive, apply my parking brake and go outside and you can see and fell my tires shake. ONLY in drive, not neutral or reverse. After the engine goes hot and I drive a while, the idle smooths out and idles fine in all transmission positions. If it were motor mounts wouldn't I feel vibration all day at every stop light in drive?
Old 02-26-2012, 08:15 PM
03TB93's Avatar
Gold 4.2L I6 2WD
i didnt feel mine ever when i drove. like you said as well, i felt it hard when i shifted into drive. all other gears were fine for some reason. and unlike you when i stopped at a stoplight it started again. maybe your mounts are not as bad as mine were and it does it until it gets warmed up. idk man.
Old 05-27-2012, 03:47 AM
nkobaissi's Avatar
nkobaissi nkobaissi is offline
2004 Chevy TrailBlazer LT
Silverstone Metallic 4.2L I6 2WD
Same Problem with the rough idle on a cold start
I'm having this exact issue. I just hit 95K and thought maybe it is the spark plugs or throttle body so I changed the plugs and cleaned the throttle body. No change. I have no idea what could be causing this. Please let me know if you find a fix.
Old 07-14-2012, 10:44 PM
kcjeff kcjeff is offline
2004 Chevy TrailBlazer LT EXT
Red Jewel Tintcoat 4.2L I6 AWD
Same here
I've noticed this recently and have no idea what causes it. I first thought about engine mounts, but it stops vibrating after it warms up a bit. Doesn't vibrate in Neutral or Park, but I really notice it when I come up to a red light or stop sign. Any ideas??
Old 11-28-2012, 10:48 AM
Curtis14 Curtis14 is offline
2006 Honda Civic
Dark Gray Metallic Other 2WD
It sounds that there is something in master cylinder or brake booster. Have you check the physical connection of of your pad to see if there is somehow any play there. You should also check the brake fluid and make sure you are not low. Low fluid can not be the cause of vibration but it could reason to lower then your usual pad.
Old 01-02-2013, 12:17 AM
20Tblazer06Ext 20Tblazer06Ext is offline
2006 Chevy TrailBlazer LS EXT
im having this EXACT same issue, its very depressing because i love my car and try my hardest to keep care of it... did you ever find out the problem? thanks in advance
