Tire help, please! - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2006 - 2009 TrailBlazer SS Tech > 06-09 SS Brakes, Suspension, Wheels and Tires > Tires
Tires Tires on your TrailBlazer SS
Old 12-01-2012, 06:20 PM
25thID 25thID is offline
2005 GMC Envoy SLE XUV
Tire help, please!
Hey everyone! I am relatively new here, and please don't beat me up too bad on this post. I had to get new lower tie rods, all 4 ball joints, and front shocks back in August. At that time, I got an alignment as well. I needed new tires as well, but had to wait 2 weeks to get them. Well, I just had them rotated (I know, I know, it;s about 3,000 miles over the 3,000 mile recommendation), and when I did, I noticed the inside tread of the tires (originally on the front, now they're on the back) was worn down to the belt. I don't drive aggressively and I haven't used the AWD or 4hi at all. I got original oem size tires. I have a 2005 envoy xuv, I6. the tires had about 9000 miles, if that, on them. I guess my questions are: 1) Is that normal? and 2) Would an alignment before I got my new tires installed cause this? Any info is appreciated!
Update: here's what I got: Michelin LTX A/T 2
Old 12-01-2012, 09:48 PM
Old Blue Old Blue is offline
2002 Chevy TrailBlazer LTZ
I have a 02 tb ltz 4x4 and I have 275/45/20. My tires have been doing the samething since I've had it.
3.73 gear ratio, Aero chamber muffler, Resonator delete, 6k hid, Drilled slotted brakes, Marvel mystery oil, Diamond White
Old 12-01-2012, 10:21 PM
So I should just suck it up? This may get expensive!
Old 12-02-2012, 12:15 AM
I'm not saying that, I got an alingment chech and everything cleared. You can still look into it but I kinda just went with it by keeping my tires rotated and balanced on a regular.
Old 12-02-2012, 09:58 AM
Sorry, I wasn't trying to be sarcastic. This whole thing kinda frustrated me!
Old 03-14-2013, 12:28 AM
looneylopez looneylopez is offline
2004 Chevy TrailBlazer LS
Indigo Blue Metallic 4.2L I6 2WD
will 225/60r16 fit
I have a 05 ls and want to put some new tires . The factory size is 245/70/16,will 225/60r16 fit and ride without problem, anybody know. Thanks in advance....
Old 03-14-2013, 01:36 AM
SnomanAndASwede SnomanAndASwede is offline
2005 Chevy TrailBlazer LT
Maybe... Depends on the tire and rim. Personally I wouldn't dare-load rating prob isn't the same which could affect how many people/gear you haul. Traction will be worse than the factory tires and handling too. Are you trying to save a few bucks? Stick to stock or go bigger. 235/70 is smallest I've heard anyone go.
Old 02-04-2015, 04:35 PM
Saltlife121 Saltlife121 is offline
2005 Chevy TrailBlazer LS
Summit White 4.2L I6 4X4
What's up guys new here will I need spacer to achieve a 265/75/r16 super swamper tires for 05 chevytrailblazer I assume I will beings the ball joint is an inch above my tire
