CTS-V rotors drilled to 6x5 bolt pattern? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2006 - 2009 TrailBlazer SS Tech > 06-09 SS Brakes, Suspension, Wheels and Tires > Brakes
Brakes Brake repairs/upgrades
Old 01-13-2011, 02:12 PM
layinbody31's Avatar
layinbody31 layinbody31 is offline
2005 Chevy TrailBlazer LS w/ SS wheels
Silver 4.2L I6 4X4
Hey guys...
I'm looking for big brake ideas for my TB and other than the super expensive SSBC kits I was thinking that if you got a set of CTS-V rotors and re-drilled the bolt pattern to our 6x5 (6x127) pattern that they could possibly work. Does anybody know if this has been tried or not? The rotors are 14" and only cost ~$70 each, so it'd be a very economical solution. Then you would need to make a bracket to space out whatever caliper you chose to run, whether it be the stock ones or possibly CTS-V calipers or a Corvette caliper of some sort (I'm leaning towards C6 Z06 myself).
One thing I'd be concerned about is the parking brake drum in the rear and the hat depth as well
Old 01-14-2011, 09:04 PM
RayVoy's Avatar
RayVoy RayVoy is offline
TrailVoy Guru
2009 Chevy Avalanche LTZ
Black 5.3L V8 4X4
Why?????????????
Switch the front to the larger setup used in the long wheel base trucks and look for performance rotors that fit.
Ray
Old 01-15-2011, 04:14 PM
tt03tbltz's Avatar
tt03tbltz tt03tbltz is offline
2003 Chevy TrailBlazer LTZ
Summit White 4.2L I6 2WD
(look im a member now)
mods: to much to list
Old 01-17-2011, 02:29 PM
Silver 4.2L I6 4X4
Originally Posted by RayVoy View Post
Why?????????????
Because the 'bigger' brakes form the EXTs and SSs are only .8" diameter bigger (12.0" on the short, I6 TBs and 12.8" on the EXTs and SSs). The CTS-V rotors are 14.0"
I like to be able to see big brakes behind the wheels, and I love the stopping performance gained by adding large brakes. The stock ones just aren't cutting it for me any more and for the price of upgrading to the 12.8" brakes I could almost put on CTS-V rotors
Old 01-17-2011, 02:37 PM
jimmyjam's Avatar
jimmyjam jimmyjam is offline
TrailVoy Guru
2006 Chevy TrailBlazer SS (LT)
White 402ci Other AWD
Google trailblazer z06 brakes... Do some reading. The baer kit is a more reasonable route. The only read difference is less fade for a few thousand dollar investment, no thanks...
I'm not banned, just locked out
banning users would hurt the site stats
Old 01-19-2011, 10:57 AM
TXSZ66AVLANCHE TXSZ66AVLANCHE is offline
2004 Non-GMT360 Other
silver birch 5.3L V8 2WD
Its not a Trailvoy but I installed a set of slotted rotors( 1" larger) , z rated pads on my Avalanche and it made a HUGE improvement! On a light trailvoy I bet .8" would make a very big difference.
2004 Avalanche- GMT900 Brakes, BB tuned, Efans, Towing Mirrors w/signals, Detroit Truetrac, Coming soon- Thunder Racing Cam!
Old 01-19-2011, 03:18 PM
Silver 4.2L I6 4X4
These are all good points, but I've read numerous posts from SS owners complaining of more than just brake fade from their stock SS brakes (which are the larger ones). Plus I'm kind of a big brake fanatic and enjoy putting large, performance brakes from one vehicle on another. Not only does it improve the appearance but the added stopping power is an added bonus
Old 01-19-2011, 03:59 PM
ScarabEpic22 ScarabEpic22 is offline
Northwest Chapter
not here not here not here
not here Other AWD
I admire the thought, but even when ADM Performance did their BBK using either CTS-V or Vette Z06 rotors it was a few thousand $$. If you want a BBK, expect to drop at least 2k, probably closer to 3k. There are some good kits being made on the tbss owners site.
Old 01-19-2011, 05:18 PM
jimmyjam's Avatar
TrailVoy Guru
like i said, do some reading. people on other sites have put their baer kits for sale as they claim it did not improve stopping distance, only noticeable difference was brake fade.
here is a direct quote from another site
Any shorter stopping distance/greater stopping power is negligible and should NOT be bought if shorter stopping distances is what one is looking for - simply too much money for negligible performance - from my point of view.
Old 01-20-2011, 02:06 PM
Silver 4.2L I6 4X4
To do just the rotors with stock calipers would cost me ~$300 (rotors are ~$70 each and I could build my own brackets. Machine work to re-drill the rotors would add some cost in there but I can't see that costing too much)
Now on top of that, you can get a full set of C6 Z06 calipers for ~$1350 (not including pads), so for around $1800-2k I could do a full set of these
