Need a DRL Killer - Page 5 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Appearance > Exterior
Exterior Exterior
Old 03-10-2011, 05:00 PM
06whitestallion's Avatar
06whitestallion 06whitestallion is offline
2006 Chevy TrailBlazer LS
DRL killer unlock and lock
Will a drl killer stop my lights from coming on when i hit the unlock or lock button on my car?
2006 Storm Troopered Trailblazer. White on Black Everythang. God Bless America... and Chevy
The Mod Bug is always biting
Old 03-11-2011, 03:23 PM
XenonKitsonline's Avatar
XenonKitsonline XenonKitsonline is offline
2003 Chevy TrailBlazer LT
if you haven't found that relay i offer HID kits starting at $79 and the relay for $25 shipped give me a call if your interested 206 465 3948 Jorge you can also check out my work at facebook.com/xenonkitsonline or www.xenonkitsonline.com
Features
- True Plug-N-Play Conversion Kit
- Safe for headlight and fog light, won't melt the housing, runs cooler than stock halogen bulbs
- Brighter driving vision at night
- 3 times brighter than halogen bulbs
- Fits into existing headlights or fog lights, no modification or retrofitting required
- Nice color output with a hint of blue (8000K Kit and higher)
- 35W power consumption compare to 55W halogen bulbs
- Bulb Lifespan of 3 to 5 years
- Ballast has shut off mode, to prevent a fire or damages if a glitch occurred.
- Ballast and Bulbs is Waterproof and Shockproof
- Waterproof connectors
- Stock color output (4300k-6000k)
relay harness is recommended for those with (DAYTIME RUNNING LIGHTS "DRL"/ AUTOLAMP)
Some vehicles might be able to power up HID conversions normally without problems at install time. It will probably not last long. The inrush load can be up to max 13 amps per ballast, compared to 7amps inrush when using halogen. The factory design parameters for headlight circuits are 7 amps inrush and 4.5 amps continuous load. So over time, connectors, multifunction switch, headlight switch, wiring and fuse holders will slowly degrade, because of heat buildup. These components are very time consuming to troubleshoot because they are usually well hidden behind dashboards and other wiring looms. Parts can cost several hundred dollars and add up to 8 hours of labor to that and it becomes obvious that relay wiring harness is a cheap insurance.
Questions:
When I start my car with the HID kit turned on, why do one or both of the lights turn off.
The lack of power and pulsing voltage when your starter is cranking may activate the safety circuit in the ballast and turn one or both off to protect itself.
Solution:
You may either start your car with your headlights turned off, or install the "autolamp / daytime running lights" relay harness.
How do I know if I need a "autolamp / daytime running lights" relay harness?
- If your car has headlights that turn on automatically when it gets dark then yes you may require a harness.
- If your DRL circuit shares with your low beam it may only output 50% - 80% power when your DRL is active and will cause your lights to flicker. That lack of power is not enough power to activate the HID ballast thus requiring a autolamp/DRL relay harness. In some vehicles you can remove the DRL relay or fuse to disable your DRL. This will stop your lights from flickering when you start your car. If you are able to disable your DRL then you will not need a autolamp/DRL harness as well.
- If you have a BMW that has a headlamp sensing system you will require a BMW harness.
If your vehicle is running at 100% operating condition you may not need a relay, however, if your electrical system does not output 12 volts consistantly you will need a relay.
Relay's recommend for most older model cars, trucks, late model cars ..
  #43
Old 03-11-2011, 03:24 PM
no it will not DRL HArness will just allow HID's to power up at 12v.
  #44
Old 01-31-2012, 08:57 PM
dd81578 dd81578 is offline
2007 Chevy TrailBlazer SS (3SS)
Magnetic Red Metallic 6.0L LS2 V8 AWD
Originally Posted by Blazernut View Post
I emailed you his email address
WELCOME!
B.
can you send me his email also
  #45
Old 08-05-2012, 10:42 PM
patrailblazer04 patrailblazer04 is offline
Forest Green Metallic 4.2L I6 4X4
drl killer
I am a new member i would like to get in touch with tblaze about buy a drl killer kit?
-Todd
  #46
Old 08-07-2012, 08:50 PM
Knucklehead's Avatar
Knucklehead Knucklehead is offline
Sand Beige Metallic 4.2L I6 2WD
^^. Hahaha.
  #47
Old 09-08-2012, 06:28 PM
ric_whit ric_whit is offline
Dark Gray Metallic 4.2L I6 2WD
Originally Posted by tblazed View Post
Just sent you a PM
I need this very bad
  #48
Old 05-07-2014, 11:55 AM
Mikemenezes Mikemenezes is offline
2007 GMC Envoy Denali
Black 5.3L V8 4X4
Just bought the VVME 55W HID KIT with harness and i get a flicker with the DLR and when you hit the key fob on my wife's 07 Envoy Danali. I thought it was the harness so i tried to install it without the harness and they didn't work at all. I don't get it. This is my 4th kit from VVME (installed various cars all with harness) My wife is yelling at me to take out the HID's and put her regular lights back in. If i read correctly this all i need to do is install the capacitor and everything will work as it should? Just want to make sure since some of the original post are from years ago. Thanks guys!
  #49
Old 05-07-2014, 12:05 PM
colt1911 colt1911 is offline
2006 Chevy TrailBlazer LT
Dark Gray Metallic 5.3L V8 4X4
Years ago, this was a much different place with members and staff and a real community.
They are all elsewhere now. Easy to find with a bit of Googling: 1st non-ad hit for the phrase "tblazed drl photo sensor"
Joke of the Day Blulytes Everything Off-Topic 1950 05-31-2019 01:13 PM
Why no 4 by 4 switch? Vader AWD Drivetrain 25 03-02-2010 10:00 PM
Angry White Man, i know i'll get in trouble for this hatchet669 Everything Off-Topic 100 07-17-2008 10:09 PM
06-07 Mustang GT vs 06 TBSS AWD jensensp Racetrack Results 48 01-31-2007 03:26 PM
