05 envoy denali no crank no start - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 11-07-2018, 05:13 PM
Denali411 Denali411 is offline
2005 GMC Envoy Denali
Black Granite Metallic 5.3L V8 4X4
Hello guys I'm having and issue with my 05 envoy denali. When I try to start it up I usually have to leave it in the on postion for a few min then it would start up. Now when I try to start it up..... Nothing. I change the ignition switch the small box under the steering colum... Same issue.... All the lights come on.... Everything works... Just when I try to start nothing everything cuts off then when I release everything lights up and working again. And idea on what's going on... Thanks in advance
Old 11-10-2018, 03:27 PM
06denaliman 06denaliman is offline
2006 GMC TrailBlazer LS
Cranberry Red Metallic 5.3L V8 4X4
Have you tried hitting the starter and see if it starts if it does its most likely your cause. Had same issue on my 06 denali. Replaced ignition switch no change then replaced starter and all fixed. Tested it the same way i just told you. If yours is a 5.3 plan for an afternoon of curse words changing the starter. Altho its really not a terrible task it is a pain. Took me 4 hours start to finish doing it in my gravel driveway on jack stands with hand tools.
Sent from my iPhone using Tapatalk
Old 11-10-2018, 05:30 PM
Thanks for the help... I'll give it a try and let you know how it goes
Old 11-10-2018, 06:41 PM
No problem def let us know the outcome
Old 06-06-2019, 08:44 AM
Been awhile since I posted but I got the starter replaced but now I'm having another issue. When I try to start the vehicle it cranks up idle rough then after 5 secs it would turn off. I would have to wait 5 mins to restart. I restarted again this time I gave it gas. It ran but when i left off the gas it would turn off. Any idea on what could be going on...Thanks in advance any help would be appreciated.
Old 06-07-2019, 10:30 AM
Sounds like air/fuel imbalance. When it does run, is the MIL illuminated? Scanned for codes?
Old 06-07-2019, 09:07 PM
Havent gotten codes pull yet will try first thing tomorrow morning. The Mil? I'm sorry new to this...
Old 06-07-2019, 09:22 PM
No worries. MIL = Malfunction Indicator Lamp aka Check Engine Light
Old 06-07-2019, 09:26 PM
Yes its on... it wasn't on prior to the starter installation..just had the starter installed now I'm having this issue...
Old 06-14-2019, 03:17 PM
Finally got the car to a shop for diagnostic and was told the computer is no good and needs to be replaced. Wanted to know is this something expensive and worth fixing....thanks in advance
