Low beam headlights shutting off while driving - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > TrailVoy Chapters > South
South
AR, LA, MS, NM, OK, TX, CO View Chapter  |  Join Chapter
Old 09-24-2014, 11:46 PM
bjgarrison bjgarrison is offline
2008 Chevy TrailBlazer LS
Exclamation Low beam headlights shutting off while driving
Has anyone else had this happen to your trailblazer? I have a 2008 trailblazer
Old 10-03-2014, 06:30 PM
firstmiata firstmiata is offline
2006 Chevy TrailBlazer LS EXT
Gold 4.2L I6 2WD
Happened to me twice in last two months. That is what I am searching. Still no clue. 06 TRBLZR EXT
Old 10-08-2014, 10:04 AM
JohnTB02 JohnTB02 is offline
2002 Chevy TrailBlazer LS
Summit White 4.2L I6 2WD
My 2002 TB has done this twice, but before I could check it out, they came back on! I swapped out the relay with the fan clutch relay, and it hasn't done it since.
Old 10-09-2014, 11:07 PM
jz jz is offline
2004 Chevy TrailBlazer LS
Sand Beige Metallic 4.2L I6 2WD
Same here. I replaced the solid state relay and solved the problem.
Old 10-10-2014, 07:41 AM
Loverotties Loverotties is offline
2002 Chevy TrailBlazer LTZ
John replace the relay for your fan clutch now that you switch it,because it's faulty.
