Temp Gauge doesnt work, A/C goes out too - Page 3 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 08-30-2018, 03:43 PM
krackerjack9 krackerjack9 is offline
same problem
I didn't thin the 2 were related but yes my coolant temp guage when it is not reading then the AC will not work so must be some sort of connection but where to look?
Old 09-01-2018, 08:55 PM
interceptor44 interceptor44 is offline
Thermostat getting stuck open.....had this problem for awhile.
They changed out thermostat and has been good for 5 days so far.....
Was told that temp has to reach around 215 for ac to kick on.
They said it was only about 160.....I don't know about that but it seems ok now. I had purchased a maintenance contract when I bought my 2008 TB about 4 years ago and the thermostat was covered. If not, it would have been 440.00
Was told it is not easy to change out (this was the Chevy dealer) so...............
  #23
Old 09-01-2018, 10:01 PM
they told you a
that's a load of crap that coolant temp has to reach 215, it might have been your thermostat sticking but when you get in and turn the key and your gauges cycle and your temp gauge stays at the bottom at 100 and don't move with in a minute or so then that is your AC problem nothing else, the signal causes the computer to not turn on the AC for some safety reason. this a a $26 fix just replace the Engine Temp Coolant sensor its a pain but its the fix
  #24
Old 09-01-2018, 11:15 PM
Well I will try that if it happens again. I was told by Chevy service department (whom I don't trust)that it was the thermostat....and they just did it I am guessing to get paid and they probably didn't want to troubleshoot. It didn't cost me anything and it's new so I said go ahead hoping that was it. Need to find a good mechanic as these dealers piss me off.
I originally went to where I purchased my vehicle and waited 5 HOURS... the service manager comes to me and says " it looks like a LOT of things going on" WTF is that??
He says "bring it to a GM dealer"!! Going to the dealer is a nightmare!!!
I will change out the sensor if it shows again...thanks!
  #25
Old 09-02-2018, 12:11 AM
well only change it out if your AC don't work and your temp gauge don't work, when the computer sees no rise in engine temp from the gauge it turns off the AC in the even that engine is overheating and the AC just puts more heat thur the condenser infront of the radiator. Only change out if Temp gauge is reading 100 or not moving at all
  #26
Old 05-17-2019, 07:04 PM
benm benm is offline
Originally Posted by ceast71112 View Post
OK I have the same problem, When temp guage does not work, the A/C will not work, After driving a while the guage will start working and the A/C at the same time. If I disconnect the battery and reconnect all works fine for a couple of trips. Has anyone found a real fix for this, The ect sensor is hid pretty well. I took a pic of what I think is the connector, will try to attch, Can anyone verify that is it? 2008 trailblazer LS, 4.2 engine
I have a 2008 trailblazer, was throwing the 128 code low coolant temp. Also my a/c used to work fine but when the low coolant issue started the a/c compressor wouldn't run until the temp gauge jumped up to maybe the middle after driving for awhile. I was going to replace the thermostat since it seems like it's sticking. Was also thinking the 2 things are related somehow?
  #27
Old 05-17-2019, 11:45 PM
Replaced thermostat in September. Still good.....no problems!!!
  #28
Old 05-23-2019, 04:49 PM
I am convinced now that the intermittent temp gauge working and the intermittent a/c working are directly related. This was the 3rd time now that when the a/c was out and the temp gauge jumped up to normal the the a/c immediately started running and cooling. Going to replace the thermostat just as a precaution and start there!
  #29
Old 06-02-2019, 09:16 PM
I replaced the thermostat yesterday, not a real easy job. So far the A/C comes on every time and my temp gauge rides right at 210 like before the problem. I will update if the A/C fails again intermittently.
  #30
Old 06-03-2019, 10:37 AM
mddombrowski mddombrowski is offline
2006 Chevy TrailBlazer LT EXT
Summit White 4.2L I6 4X4
GM disables A/C and cruise control when the engine thinks it's overheating.
