Delayed acceleration, high rpm shifts - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 4.2L I-6 Engine and Drivetrain > Transmission Mods
Transmission Mods Performance Transmission Modifications
Old 09-20-2018, 10:54 PM
Jlee33 Jlee33 is offline
Hey guys/gals. I have a 2003 Tb LT with 160k. My issue seems to be two problems with in one. I get a dleayed response with acceleration through any gear as well as high RPM revs and my truck seems to not want to shift until i let off the gas a little. It has not thrown any codes what so ever and ive even hooked it up to a top of the line snap on scanner and drove around while my mechanic buddy looked at all of the diagnostics. Everything reads normal. Any suggestions?
Old 10-30-2018, 04:21 PM
Lipstick-n-Lugs's Avatar
Lipstick-n-Lugs Lipstick-n-Lugs is offline
I'd start with a flush/filter change, personally.
Old 10-30-2018, 05:18 PM
miketexas miketexas is offline
2003 Chevy TrailBlazer LS
Black 4.2L I6 2WD
That will do nothing to alleviate his problem. It's kind of like changing your motor oil if it won't start.
Old 10-30-2018, 05:20 PM
Black 4.2L I6 2WD
Look at the scanner again and see what the TPS voltage at closed throttle is. Should close to .5 volts, or a little more. Also see if it will shift when commanded to by the scanner. Also check your fluid to make sure it's not burnt up. Also, with the scanner hooked up see what gear is being commanded when it should have shifted already.
I have a lease on the word "also".
Old 10-30-2018, 05:26 PM
Thank you Mike! Didn't see what thread my back button took me too. Went too far back.
Old 10-30-2018, 06:33 PM
Black 4.2L I6 2WD
No problem
