stall speed OE torque converter? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 4.2L I-6 Engine and Drivetrain > Transmission Mods
Transmission Mods Performance Transmission Modifications
Old 10-04-2018, 09:56 AM
Jwol's Avatar
Jwol Jwol is offline
Hi there!
Im about to rebuild my transmission, and want to swap the torque converter as well. (4.2L straight 6). I can either get me a refurbished one, or aftermarket.
Can anybody tell me what the stall speed of the factory torque converter is?
I could go 500rpm higher, but not to much as it isn't a real powerhouse.
Thanks in advance, and grtz from Germany!
Old 10-04-2018, 10:16 AM
miketexas miketexas is offline
2003 Chevy TrailBlazer LS
Black 4.2L I6 2WD
Originally Posted by Jwol View Post
Hi there!
Start the car. Put it in drive and hold the brake and floor it. Whatever the tach goes up to is really close to the stall speed. Another 500 RPM won't make much difference in anything.
The OE stall is around 1800 rpm I think.
Old 10-11-2018, 01:09 AM
RPatton76 RPatton76 is offline
New Member
2008 Chevy TrailBlazer LT
Imperial Blue Metallic 4.2L I6 2WD
I only know that at Rock Auto, it lists the stall as "High" for the 4.2L like my 2008 RWD one, and it lists "Low" as the stall version for 6.0L TB SS versions.
Old 10-11-2018, 10:05 AM
Black 4.2L I6 2WD
Those are relative terms. They should be able to give you an exact number if not then keep looking. Also most performance converter shops need to know info about your engine before they can dial you in a certain stall converter such as cam info, etc.
