4l60 issue help auto/4wd - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 4.2L I-6 Engine and Drivetrain > Transmission Mods
Transmission Mods Performance Transmission Modifications
Old 01-20-2019, 12:20 PM
Stone615 Stone615 is offline
Driving down the highway about 70, suddenly the rpms jump like it's in neutral. I get no response from forward or reverse gears, nothing from any 4wd setting. Get it to a shop, fluids are clean, the tranny is code city. Get a used tranny, same symptoms, it's also code city.
Is there a chance that it's not a tranny issue and its something else?
Can I direct swap a 4l65?
Old 01-20-2019, 02:19 PM
miketexas miketexas is offline
2003 Chevy TrailBlazer LS
Black 4.2L I6 2WD
What are the codes it has? Also will it roll in park?
Old 01-20-2019, 02:24 PM
It locks in park, I'm not sure what the codes were. I know that some were pumping solenoid etc
Old 01-20-2019, 03:58 PM
princej99 princej99 is offline
2008 GMC Envoy SLE
whats your model, year and mileage?
Old 01-20-2019, 04:19 PM
04 xuv 214k miles
Old 01-20-2019, 08:18 PM
Black 4.2L I6 2WD
I asked if it rolls in park. Can you roll the vehicle, you know, move it, in park?
Old 01-20-2019, 08:20 PM
No, park locks like its suppose to
Old 01-21-2019, 07:36 PM
Black 4.2L I6 2WD
Not rolling in park means the T/C is not shredded most likely but I'd really like to know the codes it has. Is the trans full of fluid?
Old 01-21-2019, 07:39 PM
It was full when it died, I can only work on the assumption that the mechanic filled it up all the way after swapping it
Old 01-21-2019, 10:19 PM
Does it need more than the factory 4 or 5 quarts. To prime the pump or something?
It was full when it died, I can only work on the assumption that the mechanic filled it up all the way after swapping it[/QUOTE]
