2002 Trailblazer transmission do i need to worry? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 4.2L I-6 Engine and Drivetrain > Transmission Mods
Transmission Mods Performance Transmission Modifications
Old 04-20-2019, 06:22 AM
sky_blazer02's Avatar
sky_blazer02 sky_blazer02 is offline
2002 Chevy TrailBlazer LTZ
Black Granite Metallic 4.2L I6 4X4
hello everyone this is my first post here. i recently picked up my first Trailblazer 4x4 LTZ 2002. the vehicle runs great and rides great, but this being my first Trailblazer i have nothing else to compare to. my transmission started acting funny, still getting all my gears but it just seems like the shift points are late. on a cold engine its more noticeable like almost 3k before a shift. at normal operating temp i can see 2k on a shift which feels normal with easy throttle, but if i give heavy throttle its shifting at 2500, this is operating temp. also others have said feels like overdrive is coming in late. on heavy acceleration im reaching 60 MPH and shes still shifting, this does not feel normal. i checked the fluid level and its full and doesn't smell burnt. i thought about taking her in to have the fluid/filter changed, but i keep reading about shift solenoids and them being common problems. i have no SES light and the transmission pulls strong so IDK what to think if im looking at a rebuild in the future. everything else on this vehicle works great AC, heat, 4x4, awesome LED headlight mod very little rust for a Michigan 17yr old SUV thats why i wanna make this work. any thoughts?
Old 04-20-2019, 08:55 AM
NJTB04 NJTB04 is offline
New Member
2004 Chevy TrailBlazer LS
Pewter Metallic 4.2L I6 4X4
As you said, try changing the trans fluid with Dex 6.
Quick and dirty, pull the passenger side trans line from the radiator, put a rubber hose on it to a oil drain pan, start the car until the fluid coming out sputters. Then refill and drive.
If the trans filter is partially clogged it won't help anything, so take it FWIW.
If you have access to a Tech2, you can change the shift points, assuming there is no internal damage.
Old 04-20-2019, 12:02 PM
EnvoyBoy2004's Avatar
EnvoyBoy2004 EnvoyBoy2004 is offline
New Member
2004 GMC Envoy SLT
Graphite Metallic 4.2L I6 4X4
It may pay to see if the Intake Air Temperature (IAT) sensor is working correctly. If it is feeding incorrect temp info to the PCM, the shift point will be late because it thinks the outside air is still cold. Also make sure that the ambient temperature is indicating correctly either on your inside mirror or on the HVAC panel (depending which system you have).
Old 04-20-2019, 05:19 PM
miketexas miketexas is offline
2003 Chevy TrailBlazer LS
Black 4.2L I6 2WD
Changing the fluid will not have any effect on it. If the shift solenoid(s) were bad the trans would take off in third gear all the time. it is possible one is leaking a little, but it's rare. You might suspect the TPS but at this point it's all guess work. One easy thing to do is clear the battery then reconnect it and drive it around easy and let it relearn and see what happens.
Old 04-20-2019, 09:45 PM
if the TPS was bad wouldnt i get a code? ill try disconnecting the battery, see what happens
2008 Pontiac G5 5 speed-2002 Chevrolet Trailblazer LTZ 4x4-1999 Oldsmobile Bravada AWD-1986 Pontiac Trans Am 5.0
Old 04-21-2019, 09:20 AM
Black 4.2L I6 2WD
You would usually get a code yes, but in the real world things don't always work like we expect.
Old 04-21-2019, 10:03 AM
how do i test the TPS to see if it working correctly?
Old 04-21-2019, 04:12 PM
Black 4.2L I6 2WD
The only way I know to test them is to use a digital oscilloscope. I have one and they do work, but you can get a good idea from reading the voltage coming from the tps with a scan tool. usually at closed throttle it will read about .5 volts or so up to about 4.5 or so at wide open throttle. The voltage should rise steadily but not go up and down. What did clearing the battery do? Anything?
Old 04-21-2019, 04:52 PM
i do have a scanner that displays live data and this is what the throttle position said at idle
i noticed the TPS come built in the throttle bodies so if i have to do it i gues i have to replace the whole throttle body?
Click image for larger version
Old 04-21-2019, 07:44 PM
Black 4.2L I6 2WD
On that model I believe you can change just the TPS. So, did clearing the battery have any effect?
Similar Threads
2002 XL's Envoy & Trailblazer rbagley Introductions 1 10-16-2014 07:40 PM
2002 Trailblazer AC lines different from all other years?!?!? Jeremy29 General 0 08-24-2014 01:59 AM
2002 trailblazer transmission removal from underneath the bottom of truck jrq71071 Transmission Mods 1 06-07-2014 12:05 PM
Just got a 2002 Trailblazer...transmission question mrdctaylor General 9 05-13-2014 10:51 PM
2002 LTZ Trailblazer problems: trans slip, PS leak, front end noise aliriano1 OEM Issues 3 08-02-2009 11:21 PM
