AC Line - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 05-25-2019, 03:59 PM
tcaudill tcaudill is offline
AC Line
I have a 06 envoy with a pin hole leak in the small ac line right under passenger door on top of the frame. Tried Quick Steel by recommendation of AutoZone and that didn't work. Curious if anyone have repaired AC lines and how they did it. Was trying not to have to replace the entire line. My next attempt at repairing was going to be cutting out the bad spot and splicing in a new line with the self crimping high pressure fittings. I've used them before when repairing bad spots in break lines and had pretty good luck. Any advice would be appreciated.
Travis
Old 05-25-2019, 11:50 PM
Relfan Relfan is offline
2006 GMC Envoy SLT
Silver 4.2L I6 AWD
Hose repair
If your fitting doesn't work you can find the exact diameter hose that will slip over the line and put about three clamps on both sides of the splice. You'll need to find the hose at an ac repair shop or a speciality hose shop. There really isn't that much pressure on it. If the line is steel you can braze it but that is a specialized skill and you need good access to the line. Sadly, none of the methods will work as good as replacing the whole thing. Good luck
Old 05-29-2019, 09:17 PM
SteveJL SteveJL is offline
2007 Chevy trailblazer
silver 4.2L I6 4X4
I did what Relfan suggested on a pinhole leak in the transmission cooling line, which seemed to hold up fine, much easier than replacing the whole line.-I coated the inside of the hose with some sort of sealant also.
Old 05-30-2019, 12:22 AM
EnvoyBoy2004's Avatar
EnvoyBoy2004 EnvoyBoy2004 is offline
New Member
2004 GMC Envoy SLT
Graphite Metallic 4.2L I6 4X4
Relfan- the high side line can run 150 PSI and a rubber hose may not work in a freon environment.
Old 05-30-2019, 08:26 AM
suzieq suzieq is offline
Take it to an AC shop, they will have the knowhow, and equipment to fix it right. Don't know if it can be repaired after you tried a quick fix, may have to replace the line.
Old 05-30-2019, 04:44 PM
mddombrowski mddombrowski is offline
2006 Chevy TrailBlazer LT EXT
Summit White 4.2L I6 4X4
You will need to replace the line. You risk contaminating the system with moisture and/or debris which will cost a lot more to repair.
Similar Threads
2005 Chevy Trailblazer Transmission Cooler Line Repair with Rubber swiggyswag OEM Issues 3 08-22-2018 12:29 AM
Brake Line Help Needed farden General 12 02-21-2016 10:19 PM
Attn All Trailblazer & Envoy owners check Right Rear Brake line Dutch2012 OEM Issues 2 11-23-2015 01:01 AM
Help! Power Steering line keeps bursting. JDerwae General 0 11-20-2014 06:41 PM
Transmission cooling line leaking MxRiDeR2 OEM Issues 1 08-30-2011 10:25 AM
