2006 Chevy Trailblazer - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Old 05-28-2019, 11:35 PM
healywl healywl is offline
New Member
How do I determine if my 2006 Chevy Trailblazer is equipped with a remote keyless entry (key fob)?
Old 05-30-2019, 05:00 PM
mddombrowski mddombrowski is offline
2006 Chevy TrailBlazer LT EXT
Summit White 4.2L I6 4X4
1) You receive a keyfob when you purchase the vehicle
or...
2) Your RPO label lists codes AU0, AU5 and/or AU8
Old 06-05-2019, 08:30 AM
vipergg's Avatar
vipergg vipergg is offline
New Member
2008 Isuzu Ascender
Midnight Metallic 4.2L I6 2WD
See if there is a keylock on the passenger side door, if so it does not have keyless entry . Best bet is look at the build codes in the glovebox as previous poster said .
2008 Isuzu Ascender 146000 miles
2014 Dodge Grand Caravan 96000 miles
Old 06-19-2019, 11:19 PM
akldjian akldjian is offline
2007 Chevy TrailBlazer LT
Wait, did the 06 ever come without a remote keyless entry?
Old 06-20-2019, 11:56 AM
Grinder's Avatar
Grinder Grinder is offline
New Member
2004 Chevy TrailBlazer LT
As noted if you do not have the above as mddombrowsk stated on the
Option codes on the label then yes it might not have come with it.
Do you know someone with a Trailblazer w/keyfob you could program to yours to see if its capable?
A few minutes to program yours and reprogram the donor vehicle back is not difficult.
Do not need dealer to perform the program!
Also no dealer needed for keyfob as well!
I got a spare designated 3rd driver after i programmed it from an E-bay vendor for under $10 and works perfect...
Old 06-24-2019, 09:17 PM
vipergg's Avatar
New Member
2008 Isuzu Ascender
If you dont have the AU0 code you cant just buy a fob and program it because they used a different liftgate control module .
