Motor mount replace - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > The 02-09 "How-To" and DIY Section
The 02-09 "How-To" and DIY Section Threads on Do-It-Yourself and How-To goes here.
Old 05-02-2019, 04:07 AM
Kylep Kylep is offline
2005 GMC Envoy SLE XL
Silverstone Metallic 4.2L I6 4X4
Motor mount replace
I’m getting ready to replace both front motor mounts on our 05 envoy xl 4.2 4wd. I’ve been doing a little research and have been reading that with a 4wd im going to need to remove the cv axle in order to replace the motor mount. Has anyone been able to do it without remove the axel? I was also wondering about jacking up the motor, is the oil pan the place to jack it up?
Old 05-02-2019, 08:22 PM
flyboy2610's Avatar
flyboy2610 flyboy2610 is offline
2004 Chevy TrailBlazer LS EXT
Anytime you put a jack under the oil or transmission pan, make sure to put a block of wood between the jack and the pan. This prevents the jack from punching a hole through the pan!
I find a piece of 2 x 10 works well.
Old 05-03-2019, 10:15 AM
Check on YouTube for videos on motor mount replacement.
Old 05-10-2019, 12:25 PM
Sparky234 Sparky234 is offline
2004 GMC Envoy SLT XL
Motor Mounts
You can swap the mounts without pulling the axles. it's a difficult job and I did need to grind down the length of the passenger side mount to slip it in place. Makes a HUGE difference and worth the hassle. Lots of great video's out there to help.
What size speakers can I replace my stock speakers with? z0diac Audio and Electronics 6 11-25-2008 08:49 PM
strangest way to replace a head i've seen DJDarknez General 9 09-11-2008 07:24 AM
uh oh - not again? Replace Fan Clutch $755.99 - 2004 Trailblazer rinbea OEM Issues 22 08-15-2008 05:34 PM
anyone know how to replace a lens phatkirk Exterior 3 01-31-2006 11:08 AM
How hard is it to replace rotors? envoykicker86 OEM Issues 2 12-22-2005 11:55 PM
