60-80 mph vibration fades in and out - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Brakes, Suspension, Wheels and Tires > OEM Issues
OEM Issues OEM Repairs & Problems
Old 03-05-2010, 08:58 AM
jswineaiv jswineaiv is offline
2004 Chevy Trailblazer
Ok here I go. I have a 04 Trailblazer with 4x4 I6. The Tires less than a year old and the last time I had them balanced was over the summer. My problem is once I hit around 60 mph it starts this slow vibration that fades away and comes back consistant. Now as I reach up to 80 mph it speeds up the fade in and out vibration. Once I pass 80mph it stops. At a constant speed between 60 and 80 it does this. I tried the shifting in neutral to see if I still get the vibration between those speeds and I still do as well as letting my foot of the gas. Now I feel it in the floor boards and gas pedal. Other than it being the tires needing to be rebalanced, does anyone have any ideas what it is? I know I had this vibration before in a 97 blazer due to a loose u-joint but that was constant vibration rather than a fadeing one. Plus I checked the u-joints and they felt snug. One last thing, I tried the shifting in neutral a second time but starting above 80. It was fine but once it hit less than 80 it started the vibration agian. Going on a long roadtrip to Tennessee in September for a honeymoon and I dont was this while we are driving down.
Old 03-05-2010, 09:19 AM
andrerwd's Avatar
andrerwd andrerwd is offline
2003 Chevy TrailBlazer Z71 EXT
You've already stated the first step of the troubleshooting process. Have the tires balanced and drive it to see if goes away. I had my new Dura Tracs on for 2 months and they were out of balance. Start at the cheapest and easiest first.
Livin' the American Dream!
Old 03-05-2010, 09:45 AM
GusMan GusMan is offline
2003 Chevy TrailBlazer LT EXT
Majestic Red Metallic 5.3L V8 4X4
Also look for any defects in the tires like the sidewall bulging out. That happened to us a couple of years ago. Got new tires and because we do mostly "city" driving under 50MPH, we never realized the issue till we got on the highway a month later.
We always had good luck by taking our cars to Sams for rotate and balance. Its like $16.
Old 03-05-2010, 10:07 AM
Thanks for the Tip with sams club. I will be heading there this weekend. There is no way i want to pay $40 to have my tires balanced. Ill see how it goes this weekend.
Old 03-05-2010, 11:31 AM
LMMJ's Avatar
LMMJ LMMJ is offline
2002 Chevy TrailBlazer LS
Indi-GO Blue Metallic 4.2L I6 4X4
Have you or anyone used fix-a-flat type stuff? We've had a couple where be would spin balance and add the necessary weights and re-spin to verify. We would then get a different weight reading everytime we adjusted. At some point in time the wheel spun around slow enough for us to hear water sloshing around inside it. I released some air thru the valve stem and sure enough we smelled fix a flat.
[B][U]Luis[/U][/B]
Old 03-05-2010, 11:35 AM
wiltface wiltface is offline
2002 Chevy TrailBlazer LTZ
i would check ball joints and tie rod ends as well. thats something you can do urself.
Old 03-05-2010, 12:25 PM
I never use fix-a-flat stuff. It may be helpful at the moment but in the long run you have more problems. Thats what the spare is for till you get thetire patch correctly.
Old 03-10-2010, 08:56 AM
Tires balanced, still vibration
Ok so I got the tires balanced finaly at Sams club. The frount ones took a lot of weight to balance out the tires but the back ones were fine. He rotated the tires as well. I some times seem to notice the car vibration shake around 70 mph. That was not problem in the first place I was talking about. I still feel the vibration I first posted about. To be a little more clear about the fading in and out vibration, it is more like a grinding vibration opposed to a shaky car vibration. Now that the tires are balance rotated. What are some other ideas that this could be? I have about 1500 miles left on the warrenty that sucks. I want to eleminate any possibilty of it being a part the warrenty will not cover.
Old 03-10-2010, 09:51 AM
guano2's Avatar
guano2 guano2 is offline
med grn prl & lt. pewter 4.2L I6 4X4
Get under there & check for wobble (inboard bearings), your CV axles.....
I've had a rearview mirror, seat of the pants vibration as long as I recall with my TB, ( tires, wheel bearings didn't change things, 72to80 speed range, speed range has finally gotten wider & I AM going to find the cause! ( Finally paid off, so now it's my problem) I'm at 90th now an due to service, replace a lot of stuff frt & rr shortly now that weather is improving....GL ............................. P.S. haven't found anyone directly state they solved this one yet, over the years.
[RIGHT]Those are my principles,................
....and if you don't like them... well..
..............I have others. Groucho M.[/RIGHT]
Old 03-10-2010, 11:04 AM
LMMJ's Avatar
Sounds like bad wheel sbearing/s. Is it kinda like a hummmmmmmmmmmm? Mine started on the passanger side and gradually dissapeared for a month and came back with a vengeance. It brought the left side for backup too
[B][U]Luis[/U][/B]
