Special: 6L80/90 6-Speed Automatic Transmission Conversion Special - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > Decommissioned > TRUE BLUE MOTORSPORT
TRUE BLUE MOTORSPORT Home of the DIC Harness Kit & TBSS Custom Exhaust Valances
Old 09-05-2013, 01:29 PM
ssilveronyxx ssilveronyxx is offline
New Member
2007 Chevy Silverstone TrailBlazer SS AWD & Trailblazer LH6 RS 4WD
SilverStone/Summit White Other 4X4
Lightbulb 6L80/90 6-Speed Automatic Transmission Conversion Special
Thankfully, the cost of several key components has become more reasonable to make this swap a more competitive (and in some cases less expensive) proposition to alternative 4 speed automatic "upgrades." For Pro/Con details of this conversion please follow this link: http://tbmsport.com/6l80gm6spdinformation.html
With that I am happy to present the TBMSport 6 Speed Automatic Conversion September Special. I have taken the time to get (almost) everything you need to perform this swap as painlessly and quickly as possible for '2007-09 TBSS ONLY.
Here's what you get for RWD $4595 SHIPPED(CONUS):
- 6L90 RWD Transmission( w/Torque Converter-Dipstick) Low Mileage, Recycled unit with 90 day warranty (6L80 is N/C option, but why?)
- NEW Transmission Cooler lines & fittings
- NEW custom yoke fitting for driveshaft
- NEW TBMSport Plug & Play T42-T43 Interface Module & Harness
- NEW Handheld plug in programmer for ECM & TCM reflash (Dyno tune still required for maximum performance/emissions/shift tuning to driver's liking)
- SHIPPING
AWD additional $1050 SHIPPED*(CONUS):
- NEW Aluminum Transmission to Transfer Case Adapter
- NEW 6L80/90 Specific Input Shaft for transfer case
- *Parts will not ship until Early October 2013
What is not included and/or you have to provide:
- Custom alteration and rebalancing of your driveshafts (OEM RWD aluminum driveshaft cores available)
- Minor alteration to OEM transmission mount (not the crossmember)
Want to provide your own transmission?
- Due to the wide range of specification that exists with 6L80/90 transmission (because of the varying internal components that GM specifies for the original equipment vehicles such as TCM, Torque Converter, Clutches, etc.), this is NOT recommended. Selecting the wrong 6L80/90 transmissions will result in issues that range from but are not limited to 'bricking' a $650 TCM module, destroying clutches, inconsistent performance, intermittent or non functioning electronic functions, and/or other drivetrain damage/failure. Because the 6L80/90 is an adaptive shifting transmission, high mileage transmissions are not supplied as they can mask clutch wear.
- NO guarantee will be given for the performance and subsequent issues of transmissions that TBMSport does not spec and provide.
With that said:
- the RWD September Special WITHOUT a transmission, torque converter, dipstick, yoke, and cooling lines: $2250 SHIPPED CONUS
- the AWD September Special WITHOUT a transmission, torque converter, dipstick, yoke, and cooling lines: $3345 SHIPPED CONUS
PM me for details and the most up to date availability as price and availability are subject to change without notice.
Quick reply to this message
You may not post new threads
You may not post replies
