FINAL sway bar decision guide - Page 4 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Suspension Suspension
Old 06-20-2014, 08:14 PM
RobtTx's Avatar
RobtTx RobtTx is offline
2004 Chevy TrailBlazer LS
Black 4.2L I6 2WD
Wink The Hotchkiss
My Hotchkiss is not a lift kit. It is an upgrade to the stock suspension - gives a much more stable ride at highway speeds and sways less in corners. It eliminates the rocking, swaying, seasick wagon feeling.
Old 06-20-2014, 10:03 PM
suzukiz's Avatar
suzukiz suzukiz is offline
2005 Chevy TrailBlazer LT
Repo
Yes, I know what it does, but it is the same bend as the stock bar? the rear swaybar is the lowest point on the Trailblazer and I was wondering if the aftermarket bars have any clearance differences...
  #33
Old 06-21-2014, 10:39 PM
RobtTx's Avatar
Black 4.2L I6 2WD
New bar - same fit
Both the Hotchkis bar and the Maxx links fit into the same spaces they just had a heavy-duty look and feel compared to the stock units. No clearance issues; they installed in about an hour.
  #34
Old 03-28-2016, 04:19 PM
cwedge411 cwedge411 is offline
2002 GMC Envoy SLE
Summit White 4.2L I6 4X4
I have an 2002, that needs basically everything front and rear. So i'm doing the 3" mcmaster lift. the maxxlinks, HD bilsteins in the front Skyjackers shocks in the rear.
What was the final results on best sway bars for an 02?
  #35
Old 03-10-2017, 01:16 PM
l008com's Avatar
l008com l008com is offline
2008 Chevy TrailBlazer LT
Sandstone Metallic 5.3L V8 4X4
I've replaced my tires, my shocks and my springs. Each one made a huge improvement in my trucks handling. But its still a little "bouncy". The way you guys describe this swaybar kit and bushing kit, it sounds like it's EXACTLY what I need.
But here's my question:
Should I (can I) replace the trailing arm bushings too?
What about that cross piece in the rear whose name I always forget.. the giant Z bar?
Build Thread: You can't see it because this forum automatically breaks links to other forums.
  #36
Old 12-22-2017, 05:59 PM
HellKnightHicks HellKnightHicks is offline
SLE GMC Envoy SLT
Black 4.2L I6 4X4
Originally Posted by RobtTx View Post
Hotchkis rear sway bar and MAXX links are installed. No more Grandma's Caddy! Rides rock solid, almost like my old Firebird. Wow!
Ive hated the body roll on mine since I got it...
I've changed sway bars on other vehicles and it changes them completely.
I used Hellwig on my Trucks but they dont seem to be making a bar for Envoys any more.
Going to have to do new tires and wheels really soon. May just go ahead and swap the bar out while I'm under there.
Thanks for your info.
  #37
Old 07-05-2019, 07:20 AM
Manny813 Manny813 is offline
2003 Chevy TrailBlazer LS
Metallic Dark Blue 4.2L I6 2WD
Front sway bar bushing bracket
Been all over the internet searching for front passenger side sway bar bracket for my 2003 trailblazer LS and i haven't found any. I did find the bushings but not the bracket, does anyone know where i can find it? Thank you.
Similar Threads
Sway Bar Bushings...end links amyk OEM Issues 9 10-24-2011 11:35 AM
My final Word on Sway Bar end Links unkljon Suspension 11 08-30-2007 05:20 PM
Sway Bar Clamps Breaking? Roamingdoc OEM Issues 2 07-28-2007 03:34 PM
sway bar link question Antnydude47 OEM Issues 8 07-13-2007 12:31 PM
SS fr sway bar dimensions 87octane Suspension 3 05-03-2006 09:40 PM
