quickest way to more horsepower - Page 2 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 4.2L I-6 Engine and Drivetrain > Air Induction
Air Induction Performance Air Intake/Air Induction Modifications
Old 02-27-2010, 04:26 PM
TieRod TieRod is offline
2005 Isuzu Ascender
Refrigerator White 4.2L I6 4X4
Originally Posted by jjbllngr View Post
Cheapest and fastest way to get more power is Nitrous!! Just go get a 500 shot and you'll have a EXPLOSION!!
I fixed it for you!!!
I've been really temped to do a 125 shot on mine!
BTW can anyone tell me why I can't turbo/supercharge 02'-05'?
03' 2500HD ECSB 8.1L Ally 4x4 STS turbo @ 12 psi on meth
99' Camaro Z28 was A4 now M6
05' Isuzu Ascender 4.2L
Old 02-27-2010, 04:41 PM
tbguy05's Avatar
tbguy05 tbguy05 is offline
2005 Chevy TrailBlazer LT
Summit White 4.2L I6 2WD
Long story short: PCM on the 02-05 cant handle the boost in pressure. There are several posts on this. Some get into great detail about the diff. in the early pcm's and the 06-08 pcm's.
  #13
Old 02-28-2010, 03:18 PM
wardak33's Avatar
wardak33 wardak33 is offline
2002 Olds Bravada
Pewter Metallic 4.2L I6 AWD
Originally Posted by Blazin_Trails View Post
What about a stand alone?
I also wondered that as well. Could it be possible if we were to use something like an SAFC?
2002 Oldsmobile Bravada: 4.2L I6 w/ G80 Locker, AWD, TBSS springs, HD bilsteins, 6000k HIDs, Mobil1, Iridium Plugs
  #14
Old 02-28-2010, 07:49 PM
ScarabEpic22 ScarabEpic22 is offline
Northwest Chapter
not here not here not here
not here Other AWD
If you wanted to put a voltage clamp on the MAP sensor (get a 2 Bar from a Cobalt SS first) so the PCM only ever sees 1 Bar max then run a standalone for boost conditions it *might* work.
I say 02-05s cannot do it because from the factory they cannot. I like everything to look as factory as possible, just with some more power, so unless there's not another way (Ill be looking into one come mid-May when I have access to the 02 again) I wont run a standalone. Just an FYI, the PCM will think its running at the 1 Bar MAP voltage and then whatever RPM cell, so that spark value will be carried over into boost. As for the VE, this is where it gets interesting. You'd have to spend a bunch of time on the dyno with a wideband getting into boost often and trying to use a fuel pressure riser to get the fuel delivery you need. Theres simply no way to have the P10 PCM control fuel delivery at load values greater than 100% (which I assume boost would cause this, but cannot verify).
Megasquirt should have something ready to go once they finish with all their new improvements, efi-diy knows way more about MS than I do.
  #15
Old 03-03-2010, 03:49 PM
JBMallory's Avatar
JBMallory JBMallory is offline
2005 Chevrolet TB EXT LT
Dirty White Boy 4.2L I6 2WD
Originally Posted by Toadz View Post
We could always do without the extra weight though. With the right mods we'd have a better power to weight ratio along with better weight distribution.
I heard TB's have EXCELLENT weight distribution, especially SS's at the track
265/65r17 Body Damage, QuadMod
LT-ClothInt, Sunroof, 6CD and no turn signal mirrors
  #16
Old 03-03-2010, 04:44 PM
BUC NASTY's Avatar
BUC NASTY BUC NASTY is offline
2002 Chevy BigBlazer SS Clone
Indigo Blue Metallic 4.2L I6 2WD
if you want additional hp get a yank torque converter.
SS Conversion, SSBC Brake Kit, Avic D3, 22in Rims, Efans, 6000k Kits, SS Wiper Cowl, 35% Tint, Race Mesh Grills
  #17
Old 03-03-2010, 05:02 PM
DucatiSS DucatiSS is offline
TrailVoy Guru
1969 Rambler Rogue
Camo Other 2WD
Could you please clarify and substantiate how a torque converter can increase HP.
Gone to a better place
  #18
Old 03-03-2010, 05:13 PM
T-Mac's Avatar
T-Mac T-Mac is offline
2006 Chevy TrailBlazer SS
Black 6.0L LS2 V8 AWD
I'm all ears for this one...
One thing I would do if your 2wd is change the rear end gears. No more horsepower but much better accelleration.
Supercharged and a few other goodies.
  #19
Old 03-04-2010, 08:26 PM
bulldawg bulldawg is offline
2004 Chevy TrailBlazer LT
Summit White 4.2L I6 4X4
performance
Is there a superchips programmer of any kind for the 4.2 L engine
  #20
Old 03-26-2010, 09:07 PM
Toadz's Avatar
Toadz Toadz is offline
2006 Chevy TrailBlazer LT
Silver 4.2L I6 4X4
Never get a hand held programmer for a gasoline engine. Do a search and check out the custom tuners. Well worth your money.
2000 GMC Sierra 5.3L V8 4X4
2008 Harley-Davidson Nightster
