100w LED high beams - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Appearance > Exterior
Exterior Exterior
Old 02-08-2010, 01:33 AM
flyingfischer5's Avatar
flyingfischer5 flyingfischer5 is offline
2004 Chevy TrailBlazer LS
Black 4.2L I6 4X4
100w LED high beams
Well i am going to try to retro fit some 100W LED's for my high beams. Each light puts out about 7000 lumens. So with 2 thats 14000 lumens, which is equal to about 5 sets of HID's.
The only problem is cooling them. You have to put a medium sized computer heatsink to keep them cool. Not sure what or where or how i will mount a heatsink but hopefully i can get this to work.
-Craig-
Northwest Chapter Vice President
Custom Tuned by ScarabEpic22
Old 02-08-2010, 01:50 AM
KNBlazer's Avatar
KNBlazer KNBlazer is offline
Senior Member
2004 Chevy TrailBlazer LS EXT
Steel Gray Metallic 4.2L I6 2WD
please have video rolling during initial "smoke test" ..
Old 02-08-2010, 02:11 AM
Chevy-TB-lover's Avatar
Chevy-TB-lover Chevy-TB-lover is offline
2007 Chevy TrailBlazer SS (3SS)
Black 6.0L LS2 V8 AWD
Now that will be Awesome!!
One of the LED gods around here!
Old 02-08-2010, 11:20 AM
Marty395's Avatar
Marty395 Marty395 is offline
2004 GMC Envoy SLE
Liquid Silver Metallic 4.2L I6 4X4
Post Pics ASAP! This I gotta see!
Old 02-08-2010, 12:15 PM
sonicanatidae's Avatar
sonicanatidae sonicanatidae is offline
2006 Chevy TrailBlazer LS
Silver Blue Metallic 4.2L I6 2WD
1. Make sure your wiring harness can handle that. I dont
believe the system was designed to deliver 100W, but I could
be wrong.
2. Are you *sure* they are outputting 7000 Lumens and
not 7000K in temp color? I've been looking at some of these
and I havent run across a set that claimed 7000 lumens output,
just 7000K color temp.
3. Would you really need cooling on the HighBeams? I rarely have my
highbeams on for more than 5-15 secs at a time and typically less.
Post the results. I'm considering the exact same thing. 100W LED highbeams
with a 7000K color temp to better match the 8000K HIDs I recently installed.
The difference between theory and practice is that in theory, there is no difference between theory and practice. - Moore
Old 02-08-2010, 12:16 PM
DJones DJones is offline
Senior Member
2003 Chevy TrailBlazer LTZ
Summit White 4.2L I6 4X4
Do they make LEDs that powerful? Where do I get some? Maybe water cooling will do the trick.
Old 02-08-2010, 01:16 PM
Black 4.2L I6 4X4
Here is a link to a place that has specs on the lights. I am going to do my own wiring harness(just using high beam housing), and you also need a driver because they require about 32 volts, at about 3000mA.
http://tesladownunder.com/LEDs.htm#100%20W%20LED
-Craig-
Old 02-08-2010, 01:49 PM
awer25's Avatar
awer25 awer25 is offline
2005 Buick Rainier
Platinum Metallic 4.2L I6 2WD
Wow that's insane!
PCM Tune|K&N CAI|Viper 5901|HID Lows & Fogs|Kenwood DNX9140 DVD/Nav|Alpine PDX-5 powering 2x Alpine SPR-17S & 12" Kicker CompVT
Old 02-08-2010, 11:50 PM
smalltownrp830's Avatar
smalltownrp830 smalltownrp830 is offline
2002 Chevy TrailBlazer LS
Victory Red 4.2L I6 2WD
keep us posted.
Old 02-13-2010, 03:17 AM
BPT_C20 BPT_C20 is offline
2008 Chevy TrailBlazer SS
Silverstone Metallic 6.0L LS2 V8 AWD
Yes keep us posed,
My question is why not a 55W LED so you don't need to add aftermarket wiring. Not quite as bright but still awesome.
