Coil on plug question... - Page 2 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 4.2L I-6 Engine and Drivetrain > Engine Tunes/Mods
Engine Tunes/Mods Performance Engine Tuning/Engine Modifications
Old 02-20-2019, 08:53 PM
vansmack vansmack is offline
Well that is better, because it sounded like that was for the diagnostics. I know some shops do charge a lot just to tell you what they think is wrong.
Old 02-21-2019, 10:15 AM
TB-Al TB-Al is offline
I agree on dealerships being outrageous on diagnostics. My local dealer charges $95 and almost always just goes by the codes that were thrown. $95 for 2 minutes is robbery. When I go there because I just don't want the hassle of doing the work (I just let them replace a water pump in 4 hours) I go in wearing the hat I got from a used car dealer and tell them what I want. They are very pleasant and seem to know I won't fall for the framus oil needing flushing. Then I go sit in the waiting area and listen to the old ladies telling me how framus oil should need flushing every 6 months on a vehicle this expensive.
This dealer didn't change my plugs so they always recommend it for $225 so it sounds like your diagnostics were expensive. I ALWAYS read the codes (Walmart has a $20 reader that reads most) before going to a dealer even when I know exactly what the problem is.
Old 02-23-2019, 04:54 AM
05Base 05Base is offline
I've had 1 failed coil #3 and when they fail they can foul your spark plug, you want all plugs to have the same resistance so they should all be replaced after a coil fails imo. I've replaced my plugs way more than necessary so I would say the coils are not sensitive.
Guide to changing Trailblazer / Envoy 4.2L I6 Spark Plugs w/ Images & Google Doc URL Mageler The 02-09 "How-To" and DIY Section 88 03-01-2017 12:16 PM
NEED HELP - I-6 Ignition Coil Bad? ksoldani OEM Issues 24 08-19-2015 01:48 PM
Coil Conversion Question Tools1210 Suspension 0 03-26-2014 05:08 PM
Coil Spring question Morgantwo1213 Suspension 2 01-12-2014 02:39 PM
spark plug change question signalnc OEM Issues 2 12-28-2012 07:48 AM
