Trailblazer 05, air conditioner problem?? - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > The 02-09 "How-To" and DIY Section
The 02-09 "How-To" and DIY Section Threads on Do-It-Yourself and How-To goes here.
Old 02-10-2019, 11:45 PM
moshviki moshviki is offline
Hey, I have a question, Chevrolet Trailblazer 05, when the air conditioner is on heating, only the driver's side heats up and the rest of the car only takes out cold. Anyone know? idea?
Sent from my ONEPLUS A3000 using Tapatalk
Old 02-11-2019, 01:51 PM
The passenger side blend (temperature) actuator is probably bad or stuck. This is common with these, the plastic gears break or strip. Check out the thread link below for figures on location of actuators.
https://forums.trailvoy.com/showthread.php?t=123458
Old 02-11-2019, 02:04 PM
Thank you very much,
I will try tomorrow if there will be some time to identify and dismantle it
Old 02-13-2019, 09:21 PM
Czinful Czinful is offline
My 07 TB has begun an issue with the temperature controls. With both the drivers side and passenger side set to max high temp, it will sometimes begin to blow cold from one or both sides. I can hear the blend actuator adjust when this happens.
I run the controls up and down a couple times, and I can hear the blend actuator adjust and the heat comes back. I’m gonna replace my controls (I also have an intermittent back light in the controls). But as long as I still have heat, I’m gonna wait for warmer weather. It’s been pretty cold here in MIchigan lately.
Old 02-26-2019, 04:05 AM
timcarter timcarter is offline
Originally Posted by moshviki View Post
Hey, I have a question, Chevrolet Trailblazer 05, how to delete snapchat when the air conditioner is on heating, only the driver's side heats up and the rest of the car only takes out cold. Anyone know? idea?
The plastic gears break or strip...
Old 02-26-2019, 05:26 AM
Okay, I dismantled the two actuators under the steering wheel. I played with the shutters in the canals. But none of them controls the parties. So no matter what condition I put the shutters still the driver it warms and the rest of the passengers it takes out cold air
CAI: Which one do you have? Jman423 Air Induction 138 03-01-2015 09:11 AM
[SOLVED] [New, Not Solved] trailBlazer LT 2005 problem bluenight The "How-To" and DIY Section 0 02-27-2013 05:08 AM
wierd rear air problem jigubhai2001 General 6 06-23-2011 01:00 PM
Air Conditioning Problem, 2002 Trailblazer dannystroh OEM Issues 23 06-14-2011 09:35 PM
Air Conditioner Problems? Dee_N_Eldon General 26 09-15-2010 11:35 PM
