24" stock rims - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2006 - 2009 TrailBlazer SS Tech > 06-09 SS Appearance > Exterior
Exterior Exterior repairs/modifications
Old 03-31-2012, 09:49 PM
07ssbeast 07ssbeast is offline
2007 Chevy Trailblazer ss
candy red 6.0L LS2 V8 AWD
24" stock rims
Does gm make a 24" stock rim? couldnt find anything on google thought id check here..
Old 04-01-2012, 04:02 PM
XxUnReAL713xX's Avatar
XxUnReAL713xX XxUnReAL713xX is offline
Indigo Blue Metallic 4.2L I6 2WD
nope just 22s is the biggest gm makes
Old 04-01-2012, 05:45 PM
Where is the best place to get a set of these wheels? Can you order them with tires and do they rub at all?
Old 04-01-2012, 06:53 PM
Mad Dog Mad Dog is offline
2007 SAAB 9-7x
Graystone Metallic Other AWD
Just to clarify, GM doesn't make a 22" for the Trailblazer either just for other models in other designs.
The largest GM sourced wheel for the TB bolt pattern is the 20" found on the Trailblazer SS which you likely have already. There are some aftermarket companies who have made reproductions of these SS wheels in the larger 22" size.
A quick look on ebay will turn up the 22" reproductions. They can be ordered with or without tires. And if you purchase the correct size tires then no, they will not rub on a TBSS.
Old 04-05-2012, 02:12 PM
gm does make 22s he didnt mention trailblazer he said gm thats why i said yes i ordered the ss replicas from a local rim shop they gave me a pretty good deal 1750 with tires
Old 04-06-2012, 12:31 AM
wickey wickey is offline
2008 Chevy TrailBlazer LS
Cool 24 inch rims
anything can be done,i seen aftermarket looking ss wheels 22 and 24s on craigslist,but they wernt for trailblazer,adapters?
Old 04-06-2012, 06:17 AM
2007 SAAB 9-7x
Yes, you can run adapters to get these to fit, with the right tires of course. The larger rims will have to come from the GMT900 trucks if they are factory. You can fit lots of aftermarket wheels with the right adapter, offset, and tire combination.
I didn't say you were wrong, but since you didn't specify and the OP didn't specify it might be nice to make sure that we're all on the same page so I clarified the different applications.
Old 05-20-2013, 05:34 PM
shortyc303 shortyc303 is offline
They make 22 inch SS look a likes...won't rub depending on tire size...I'm running 24s no rubbing...also if u go with adapters make sure u get the right offset wheels or they will stick out a lot!!,
Old 07-12-2013, 08:27 AM
mrinken mrinken is offline
2006 Chevy TrailBlazer SS (3SS)
Black 6.0L LS2 V8 AWD
Tony on TBSSowners.com/store sells the Factory Reproductions 22's for for the TBSS style - and claims he'll beat anyone's price.
