Making A Heat Shield For My Intake - Page 3 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 4.2L I-6 Engine and Drivetrain > Air Induction
Air Induction Performance Air Intake/Air Induction Modifications
Old 06-25-2006, 10:15 AM
ieatglue's Avatar
ieatglue ieatglue is offline
TrailVoy Guru
2003 Chevy TrailBlazer LT EXT
Onyx Black 4.2L I6 4X4
Originally Posted by dntnvme
Great Job, Looks great. If someone would like I have Autodesk Inventor 10 coming in the mail. The program is huge tho 3.2 gig DVD-rom.
Can I get a copy of it? I know they're HUGE!! I tried copying it off the school computer but it was way too big
Horsepower is how fast you hit a wall, Torque is how far you take the wall with you
[SIZE="2"][COLOR="Red"]THESE BIG RED LETTERS HELP ME FIND MY POST[/COLOR][/SIZE]
Old 06-25-2006, 10:26 AM
jjsryd's Avatar
jjsryd jjsryd is offline
2004 Chevy TrailBlazer LS
Summit White 4.2L I6 2WD
Hey Glue, you can always just spray paint that cardboard piece. Problem solved.
JJ, Lisa n Jonny.
2004 TB LS {R.I.P.}
  #23
Old 06-25-2006, 03:13 PM
ieatglue's Avatar
TrailVoy Guru
Maybe I should
I bought some aluminum sheet from RONA and some pipe insulation wrap to cover the outside of it and i'm gonna cover the pipe too because I bought too much lol
Total cost so far is $20 Canadian. $4 for the aluminum and $16 for the pipe wrap
  #24
Old 06-25-2006, 03:52 PM
TBlazinBoomer's Avatar
TBlazinBoomer TBlazinBoomer is offline
2006 Chevy TrailBlazer LT
Aluminium
I think aluminium would work fine for what you want to do. What you might do is get some small peices of aluminium like 2"x2" and make test peices. Paint them with diff paints and such, you can even get that rhino liner stuff in a can. I don't think it's "Rhino liner" but the same kind of stuff? Put these peices in a hot part of the eng, but where it will cause no damage like next to the exhuast manifold to see what will stand up to the heat. You might even try some of that BBQ Grill paint, they make a few diff colors for grill paint. If it was me I would just go with the aluminium look or maybe sand it to give it that brushed look. Aluminium will get hot, but it also should cool down fast too. When or if you try the peices try differant thicknesses to see what will get hotter and stays cooler. You don't have to put it next to the manifold it was just an idea, but where you are putting the shild at would be just fine.
Good luck, I will like to see the finished product.
Boomer
  #25
Old 06-25-2006, 06:59 PM
ieatglue's Avatar
TrailVoy Guru
I cut out the aluminum sheild. Took 1 hour and about a gallon of sweat Then I spray painted both sides with some black high heat paint. Took the Intake off, wrapped it with the pipe insulation, then put some on the outside portion of the heat sheild. I was pretty surprised at how much wrap I had left over. I think I only used a quarter or a third Then I put it all together...
BTW, does my TB look dirty?
  #26
Old 06-25-2006, 07:07 PM
ghoster ghoster is offline
2011 Chevy Tahoe
Mocha Steel Metallic 5.3L V8 4X4
Looks good glue. How close to the hood is it when you close it?
  #27
Old 06-25-2006, 07:45 PM
ieatglue's Avatar
TrailVoy Guru
it's about half or a quarter inch away, very little. I was thinking of some rubber tube that I could put on the tip of the sheild to completely seal the gap, but I seriously don't wanna spend any more on it. It only cost me $20!!!
  #28
Old 06-25-2006, 07:47 PM
Vince's Avatar
Vince Vince is offline
Senior Member
No longer own a TV. No longer own a TV. No longer own a TV.
No longer own a TV. Other 4X4
Good job on the heat shield. Your "hold down" for the intake looks just like what I used to have.
Now I have on the hollowed out stock box.
edit: email is french for high? I never knew that.
  #29
2011 Chevy Tahoe
yep....The airaid one comes with a rubber seal around the top edge. I was thinking that maybe you could find some sort of door moulding that would work. It can't be expensive for as small a piece as you would need. Looks really good so far though!
  #30
Old 06-25-2006, 07:56 PM
ieatglue's Avatar
TrailVoy Guru
Mine actually came with 3 zip ties I bought a tool bench and it came with 2 mire straps. I cut a piece to size, painted it black and used it as a tie down When it comes to making stuff, I can do anything
Je tres e'mail
Similar Threads
If you're the TBSS guy that helped me out today, PM me...Here's my race story 02-Bravada-88 Racetrack Results 51 11-03-2013 02:42 PM
Why no 4 by 4 switch? Vader AWD Drivetrain 25 03-02-2010 09:00 PM
Uh-Oh....Looky here! 85vette Latest GM News 21 04-18-2008 01:54 PM
Cam installation, various tips for the DIY'ers.... 02redhawk Transmission Mods 5 07-09-2007 10:09 PM
PCMforless Introduction Special - $99 tuning! [email protected] PCM of NC 94 04-11-2007 10:50 PM
