Fuel Injector cleaning? - Page 3 - Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum
Go Back   Chevy TrailBlazer, TrailBlazer SS and GMC Envoy Forum > 2002 - 2009 TrailBlazer/Envoy Tech > 02-09 Vortec 4.2L I-6 Engine and Drivetrain > Air Induction
Air Induction Performance Air Intake/Air Induction Modifications
Old 09-24-2005, 04:17 PM
Dj Perico Dj Perico is offline
Originally Posted by ScarabEpic22
Thanks man, I will look into it.
Me too. Sound like a good product.
Old 07-14-2009, 05:17 PM
Jostrowski Jostrowski is offline
2005 Chevy TrailBlazer LT
Engine Problems
Hello Guys,
I have a 05 Trailblazer LT with about 39K on it. Today I notice that when I was driving home from work, and I was stopped in traffic, my TB would run ruff. Like it wants to stall, but doesn’t. The RPM's drop below 500, but just for a milosec, and then it goes back to normal. No hard braking, no hard acceleration, no anything special about the TB. Would anybody recommend that I get Fuel System Cleaning done? I live in Houston, and at firestone, they will do it for 89 bucks, but the dealer wants 189 for it. What do yall think? My ears are open to get the problem fix. Thanks
  #23
Old 07-14-2009, 06:31 PM
2003 GMC Envoy SLT
Have you cleaned the throttle body yet? If the engine runs rough when the A/C is turned on the t-body needs cleaning. As for the fuel system cleaning, try a bottle of Chevron Techron or Seafoam first.
  #24
Old 07-14-2009, 11:15 PM
No, I have never cleaned the T-body. It it hard to do? I'm a pretty good car guy, but just affriad of breaking something off. What do you recomend? Cleaning the t-body, or dumping in some cleaner? What do you give cleaning the t-body a hard rate scale? 1-10, 10 being really easy and 1 being super hard that you wouldnt even want to do it? What type of cleaner do i use to clean the t-body with? Thanks
  #25
Old 07-14-2009, 11:55 PM
BigJohnAZ's Avatar
BigJohnAZ BigJohnAZ is offline
2003 Chevy TrailBlazer LS
Indigo Blue Metallic 4.2L I6 2WD
[QUOTE=LAVABOY;20358] Maybe another good tip is if there is a tanker filling up the station underground tanks, go to another station. A friend told me once that when they are pumping in gas it stirs all the sediment in the tank. I don't know if this is true but it sounds logical
I might buy that, but there are also filters on the fuel delivery system, so personally, I've never had an issue ever, with any vehicle. Even when fueling up with the tanker unloading.
I used to go to this one gas station years ago when I used to work in Carol Stream and I would be able to tell when his filters needed changing, the fuel delivery from the pump slowed quite a bit.
I have been notorious for allowing my tank to get to fumes. When I change my fuel filter, they're always spotless. I have always said, buy good gas ans you should have no problems. Like my throttle body I just cleaned last week. 81k miles and I really didn't need to. I buy top tier gas and change my air filter regularly.
BigJohnAZ
2003 LS Indigo Blue Metallic
  #26
Old 07-15-2009, 12:06 AM
2003 GMC Envoy SLT
It is easier than changing spark plugs. A spray can of t-body cleaner, some rags and a set of sockets. Check this post: https://forums.trailvoy.com/showthread.php?t=51619
  #27
Old 07-15-2009, 12:12 AM
2003 GMC Envoy SLT
[QUOTE=BigJohnAZ;780913 I have been notorious for allowing my tank to get to fumes. When I change my fuel filter, they're always spotless. I have always said, buy good gas ans you should have no problems. Like my throttle body I just cleaned last week. 81k miles and I really didn't need to. I buy top tier gas and change my air filter regularly.[/QUOTE]
The t-body never comes in contact with fuel. It gets dirty from blow-by. If the engine is tight enough to keep blow-by down, the t-body will stay cleaner.
  #28
Old 07-15-2009, 09:09 AM
Thanks guys, I guess I will be cleaning the t-boday today and not getting a Fuel Injector Cleaning Service done. I hope this will fix the problem. Thanks for everyones thoughts! Thanks again!
  #29
Old 08-08-2009, 03:59 PM
daharv16's Avatar
daharv16 daharv16 is offline
2004 GMC Envoy SLT
Carbon Metallic 4.2L I6 2WD
TB Cleaning
Hey Jostrowski, how did the TB cleaning go? Did it take care of the stalling symptom? I have an '04 Envoy doing the same thing although it will actually stall sometimes but starts right back up. Just waiting for cooler weather before getting under the hood.
Similar Threads
Gas smell clodeb OEM Issues 14 04-26-2008 10:15 AM
WARNING - Lingenfelter Fuel Pump Kit Seal Shipment ERROR! jrh General 0 03-01-2008 11:03 AM
Fuel pump inop fastrc51 OEM Issues 1 02-14-2008 11:47 AM
GM Notification of Fuel Leak Issue Viper12873 General 2 06-22-2007 11:08 AM
Gen IV 5.3 LH6 Info... Windy City Engine Tunes/Mods 7 08-08-2006 10:41 AM
